I am wanting to remove the nag screen. When entering testmodes file management, I do not see a user folder anywhere. Do I need to look harder or is the NAVI.exe hidden elsewhere? Thanks!
The USER is in the root directory of the earlier units. The AVIC-Z150BH has the following root structure:
HDD
HDD2
HDD3
HDD4
NAND
NAND2
NAND3
NAND4
SDCARD
USB
RAMDISK
DVDCD
Where are you at in the process? Thanks.
As far as USER directory, it is in: /NAND2/INITDATA/.
In regards to NAVI.exe, the files with the .exe suffix, only appear* to be VrTest.exe located in /NAND/NX133/PRG0/APL and /NAND/NX133/PRG1/APL and diff indicates: "Binary files NAND/NX133/PRG0/APL/VrTest.exe and NAND/NX133/PRG1/APL/VrTest.exe differ."
There are some large files that I think we need more information on, image.iarc found in /NAND/NX133/PRG0/APL/Resource/Mame/ and /NAND/NX133/PRG1/APL/Resource/Mame/. In addition, there is EU130PLT.PRG found in both /NAND/NX133/PRG0/PLATFORM/ and /NAND/NX133/PRG1/PLATFORM/.
If anyone has insight into what *.iarc, *.LFT and *.PRG files are, please share. Thank you.
* I do not know exactly which files failed to copy when I tried to backup the /NAND/SYSTEM/ directory and because of this I use the word appear. There also may be executable files within other extensions and whatnot...
I came from an F series, which I was hoping this unit was built from...but I see no. I gave up and deal with the nag screen, I did reply to your PM
