NEX Mic and Apple Carplay
By pduncan1963 · Jul 27, 2015in NEX Series💬 11 posts👁️ 3,332 views
Posted Jul 27, 2015 · 14:08 UTC#1
It seems that when you are in Apple Car-play that the AVIC mic is not enabled to give Siri a vocal command (Hey Siri, then the command call so and so) .
To prove this, I put my car-play connected phone in a location (while plugged into the usb) where the phone could not pick up my voice command and spoke directly into the AVIC-8100 mic. Nothing happened. I then took the phone out of the glove box, sat it in the seat next to me, covered up the AVIC Mic and tried the same voice command. This time Siri picked up on it.
Has anyone else noticed this? Seems strange that Apple or Pioneer would have overlooked this as part of the Apple Car-play.
Edited Jul 27, 2015 by pduncan1963
Posted Jul 27, 2015 · 17:53 UTC#2
Not my experience. iPhone 6, latest OS, using CarPlay (ie: plugged into Lightning cable attached to USB1 on my 5000), I say Hey Siri <xxxx> and it responds perfectly.
Posted Jul 27, 2015 · 19:43 UTC#3
Try sticking your phone somewhere that the phones microphone can't pick you and see if she still responds. I've got Iphone with latest os also.
Posted Jul 27, 2015 · 20:01 UTC#4
Only 1 place for me to put my phone unfortunately and that's in the console as that's where the lighting cable is. But I did try it with a covered up phone (in a blanket) and it still worked fine.
If I'm listening to music or talk radio or the road noise is loud (open windows esp bad), it can be hard for CarPlay to pick up on the "hey siri" command. And it's important to remember that once you plug in the lightning cable, the mic being used changes from the phone mic to the NEX mic. Once you disconnect it, it goes back to the phone mic. And even then it needs power.
Not sure why yours is not working properly. Perhaps cycle the Hey Siri toggle switch off then on again on your phone? Not heard of anyone here not having the Hey Siri command not work when plugged in. Sorry
Posted Jul 27, 2015 · 22:47 UTC#5
"Hey Siri" worked fine for me until recently, now out of the blue nothing happens when I say this command. Very strange indeed. I cycled the "Hey Siri" toggle on my phone, moved the phone to different places, still no luck.
Edited Jul 27, 2015 by herbert68
Posted Nov 10, 2015 · 12:00 UTC#7
Same issue here.
Posted Nov 10, 2015 · 20:35 UTC#8
What a difference 3 months makes. I'm finding the same issue now. Weird.
All I did was deactivate and then reactivate the Hey Siri command and it seems to work now.
But TBH I don't use the Hey Siri command much I just hold my Home button down for a few secs and then Siri is good to go.
Posted Jan 07, 2016 · 01:59 UTC#9
So I hate to be the ignorant one here, but how does the "Hey Siri" function work with the NEX (I have a 4100) and Carplay? Does it only work when you have access to the NEX mic and not the phone mic?
Posted Jan 07, 2016 · 02:16 UTC#10
On your Iphone You need to go to settings, General, then Siri and there is an option that says Allow "Hey Siri" Since I'm Jailbroken I have two additional options for While charging and for Always.   Also On my 4000NEX and 4100NEX Hey siri works through the Mic perfectly or you can hold the home button on the radio.
Posted Jan 07, 2016 · 04:24 UTC#11
Right. I use it on my phone. I just didn't think it would work through the NEX unit. But it seems like it works through the NEX mic but not through the iPhone mic when connected.
