Solution to 32GB micro SD card limit
By EvgaGaming · Aug 02, 2015in NEX Series💬 5 posts👁️ 2,514 views
Posted Aug 02, 2015 · 01:31 UTC#1
All,
I believe I found a solution that will allow us to seamlessly use cards larger than 32 gb limit, including the monstrous ones larger than 128 GB.  I'm going to purchase a large card and follow the steps here:
http://gearnuke.com/use-64gb-bigger-microsd-cards-android-device-maxes-32gb/
Let me know what you guys think.  I'm anxious to try this out.
Edited Aug 02, 2015 by EvgaGaming
Posted Aug 02, 2015 · 02:03 UTC#2
I have been using a 256gb card since February, I tried 64gb, then 128gb and finally a 256gb. I used a macbook pro to format, using disc utility and never had an issue. There are over 200 ripped dvds, 70 are mp4 movies purchased on iTunes, that were converted from m4v with Apples protection. The program removes the protection and converts to mp4.
Posted Aug 02, 2015 · 03:04 UTC#3
Joemamma, as usual always value your depth of knowledge.  However, as we've discussed the problem lies in the fact that you can't write on these large cards since the data will eventually get corrupted.  With the hack above, I'm wondering if the writing problem is solved.
Posted Aug 02, 2015 · 05:54 UTC#4
It is the exact same way that has been used before, nothing new.
Posted Aug 02, 2015 · 19:52 UTC#5
Gotta give him credit for trying to help.
