D3/BT: New phone won't auto connect
By jonyb · Sep 12, 2007in Problems/Troubleshooting💬 13 posts👁️ 1,572 views
Posted Sep 12, 2007 · 01:09 UTC#1
I've got the D3 and the BT module to go with it, and I'm using a Verizon Wireless Blackberry 8703e. The phone was crushed the other day by an 85lb. dumbell so I had to get a new one.
The previous phone would automatically connect to the bluetooth when the head unit powered up or I got back in it while running. The new phone will not do this. I've been through everything as far as checking the settings from the "menu" button while on the BT function, I've swapped BB's and tried others with no luck, and I've changed all the settings in my phone and nothing seems to work.
You have to manually connect the phone to the head unit everytime, and on a BB that's about 6 button presses. Not even worth it for a short trip. Once the phone is connected, everything works properly, it's just that it won't automatically connect.
Any suggestions?
Posted Sep 12, 2007 · 04:17 UTC#2
did you still have the old phone registered in the 1st slot? Cuz the D3 seem to autoconnect only to the 1st slot. Also, check to see if auto connect is set to on.
Posted Sep 12, 2007 · 14:03 UTC#3
Thanks for the reply. I've deleted the first phone, and the auto connect is set to on. Now that I think of it, I can't remember if the new phone is added on that first slot. How can I add it? The head unit and phone are paired and work, but I'm not sure if it's added in that slot...
Posted Sep 12, 2007 · 16:02 UTC#4
You can try and reset the BT unit. That should erase all the current information and previous pairings. This will also delete contacts you pushed to the unit, so up to you.
Posted Sep 12, 2007 · 16:19 UTC#5
Thanks, I'll try that. I lost the contacts stored in the unit a couple weeks ago because I had to have the D3 replaced.
Posted Sep 12, 2007 · 16:30 UTC#6
myvekdrifters there are plenty of other good avatars out there. :evil:
Posted Sep 13, 2007 · 03:12 UTC#7
sorry buddy...i can't find a descent avatar to represent myself using a d3 but a d3 image. the gallery doesn't have it...hope you don't mind...if you do i'll repalce it and put up my Emperor logo...Mitsubishi Lancer Evo Emperor...one of the best club sport for Lancer Evolution.
Posted Sep 14, 2007 · 05:38 UTC#8
Just kidding :D
Posted Sep 14, 2007 · 11:27 UTC#9
On your BB, be sure you set the Pioneer BT unit to trusted and auto.
Posted Sep 14, 2007 · 22:20 UTC#10
I did that...
I also tried the "Device Name" to be 0000 so it would skip a step and that didn't work.
Under "Device Properties" on the phone I have the following:
Device Name: 0000
Trusted: Yes
Encryption: Enabled
Echo Control: Automatic
Under "Options" I have:
Device name: 0000
Discoverable: Yes
Allow outgoing calls: Always
Address Book Transfer: All entries (Like it matters because Verizon screws us up on that)
Posted Sep 15, 2007 · 04:07 UTC#11
You said you have already made connection. From what I'm understanding you can't seem to get it to autoconnect. Were you able to register the phone yet? I mean, on your D3 AV Menu, BT phone, tap Function, Phone Register, and make sure the first slot there is your phone and not anyone else. If not, delete it, and make connection to your current phone, if not yet connected. And hold that 1st slot until your phone displays in that slot.
If not, try resetting in one more time on your Blutooth first, then if not, your D3 and Blutooth. And try again. Otherwise, your phone is not searching. Try resetting your phone as a last resort. otherwise, i'm stuck like you. :roll:
Posted Sep 15, 2007 · 04:10 UTC#12
oops, i meant your phone is not sending signal to be discoverable.
Posted Sep 15, 2007 · 10:36 UTC#13
I did that yesterday and what I hadn't been doing was adding it to the list. Works just fine now.....
Thanks for all the help fellas! :D
