Hi,
I tried to search through the forum for something similar, but I haven't found anything. I've had my 8100 for about 6 weeks now, having put it in my 2015 Subaru Forester. I installed it myself, soldering all of the wiring ends. I grounded out the parking brake wire and did the software bypass. Overall, the unit works really well. However, every now and again (probably about once every 2-3 weeks or so), I'll turn on the car after not having driven it for a bit (say, in the morning), and the boot splash will come up and then it just gets stuck on the "loading" screen. If I have music playing, I have no control over it at that time (even though other times I can change the volume, etc...). I shut down my car and restart it and then the whole HU remains dark for about 30-40 seconds, eventually bringing up the boot splash. If I shut it down again and restart the car, it'll then come back up on it's own just fine. Sometimes on that 3rd time when it comes back up, it'll give me an error that the parking ground is set incorrectly. But everything works fine after that. Then it'll work totally fine for another week or two and repeat itself (usually when I'm in a hurry to leave for work or sometime when I don't really have the time to sit there and restart the car multiple times).
I have the latest firmware on it. I have gone back and checked my soldered connections and everything appears to be pretty solid (I sealed all the joints with heatshrink tubing as well - plus I have lots of soldering experience). This seems like an intermittent software issue. I had originally thought that it was due to my phone (I have a Note 3), as it seemed that when I had it plugged in at boot, it would do it more, but I have since been able to make it do it multiple times with the phone totally disconnected. I thought it might be a heat/ventilation issue, but it seems to make no difference as it does it when my car is in the hot sun and when it's 65 degrees in my garage.
Has anyone else run into this situation?
