It's all good. All I'm trying to do is helping others by trying to solve this problem until there is a testmode. My idea was to trick the system and install other maps from "sync tool" folder that naviextras toolbox create from various igo primo systems. If we can get all the maps and licenses into one synctool folder, we can install the world map on any device that uses igo primo.
It is possible to cheat naviextras toolbox and upload your own files without using testmode. But you can not use any uploaded maps using testmode or using naviextras toolbox without proper licenses for your device model/region or for you device's id. update: Also, synctool folder contents is signed with md5-checksums of files, so it is impossible just to rewrite or add your own contents. Both naviextras toolbox and headunit's synctool will refuse this. But there is a way around this problem, you also need to be familiar with many things like md5-checksum calculation, editing files in right encoding and so on. It's hard to implement.
It is possible to hack this system and upload fresh maps for any region, but this is very complex task and it's hard to do this. You need at least two head units of different regions to do this. Also, at this moment you also should disable WARP (like hibernate function in windows), that causes significant increase of head unit start time.
Just for example: EU version of F960BT with maps of Russian Federation (not included in default maps set):
Also it is possible to install any other navigation software (including "right" versions of iGo software), but this is also very complex task at this moment. You need to be familiar with shell scripts, android internals and so on. Also, it is very easy to do something wrong and brick your device.
