"There is no applicable Program" - F920 Series - F9210BT
By leorphee · Sep 04, 2015in Problems/Troubleshooting💬 9 posts👁️ 4,500 views
Posted Sep 04, 2015 · 15:17 UTC#1
Engl:
I tried to update my F9210Bt the 2015, but made some mistakes and then flashed the 2013 update.
Now comes at the start of the AVIC always a boot loop.
I can select any language, he start again and again.
check out the video. I ask you for help. Thank you very much.
Ger:
Ich habe versucht auf meinem F9210Bt das 2015 Update zu machen, habe aber einige Fehler gemacht und dann das 2013 Update geflasht.
Nun kommt beim Start des AVIC immer eine Boot schleife.
Ich kann keine Sprache auswählen, er starten wieder und wieder.
schaut das Video. Ich bitte Euch um Hilfe. Danke schön.
https://youtu.be/w9oAH8x_udg
Edited Dec 17, 2015 by leorphee
Posted Sep 04, 2015 · 15:26 UTC#2
Search on pioneer site for updates and install them.
It worked on my f930bt when i installed 2013 maps. I got the same loop.
I updated radio update and then the problem was solved.
Maybe try the last updates, if you already instaled them, again.
Let me know if it worked.
Edited Sep 04, 2015 by CELL
Posted Sep 04, 2015 · 17:26 UTC#3
so, i have 5 different SD Cards an all formattet new (notQuick)
1st with Testmodkey and RenewallFLib.dll
2nd with the last Pioneer update from the Pioneer Site: AVICF20BT_APL2.00300.zip (last Firmware Update 30.08.2010)
3rd with the 2012 Update from here (it works)
4th with the 2013 Update from here with the edit CADRINFO.cif and VERINFO.DAT (i have Instal them 2013, it works)
5th with the 2015 Update from here with the edit CADINFO.cif
I try the 2nd, 3rd and the 4th Update with the original RenewallFLib.dll
but nothing change the Boot loop
I try the 2nd, 3rd, 4th and the 5th Update with the edit RenewallFLib.dll
what shall i do???
What am I doing wrong?
I destroyed my avic?
Edited Sep 04, 2015 by leorphee
Posted Sep 04, 2015 · 19:09 UTC#4
Damn I play to mutch, my Car Batterie is off.
Posted Sep 04, 2015 · 21:04 UTC#5
I think language selection function as following :
Menu which language is selected calls an unzip of the selected language files.
So perhaps it is so, that you have choosen a language which is NOT in the 2013 update. Unzip fails, Avic boots, recognizes the missing languages files an reboots.
Last year i updated a F900BT to 4.0001 or so and only english language files where in the update. Because i knew that, i never changed the setting. Last week I downloaded
a copy of the 2013 Update withe all language files and copied them to the unit. Now language selection works.
Just a hint, no warranty ;)
Posted Sep 05, 2015 · 16:32 UTC#6
Now i can install the updates from 2012 and 2013, after the install - reboot and than it comes allways the Boot Loop back.
The last Update from the Pioneer Site I can't Install,
for the 2015 update is not enough time to enter the password. it start the reboot....
Now I hear the radio till the AVIC reboot. and reboot and reboot.
Is there a Chance to make a reset from the Unit or anything else?
Edited Sep 05, 2015 by leorphee
Posted Sep 13, 2015 · 11:24 UTC#7
Is there perhaps someone who copied the folder from his unit and gives it to me?
Posted Oct 04, 2015 · 12:09 UTC#8
Damn
what can i do?
Posted Mar 11, 2016 · 06:22 UTC#9
Seems only clone device via hardware programmer will help.
