Desperate for help! Appradio 4 + PAC RP4-HD11
By Saintvale · Sep 11, 2015in AppRadio, AppRadio 2, AppRadio 3💬 1 posts👁️ 2,204 views
Posted Sep 11, 2015 · 05:00 UTC#1
:???: Sorry for the long post, but please read!
I just received my Appradio 4 and PAC RP4-HD11 for an install in my 2014 Honda CR-V. I'm really confused about a few things so here goes:
1) The PAC unit has what looks like 4 RCA connectors for speakers coming out of it (see pic A) but the wiring harness for the Appradio 4 can't connect to these (see pic A)... The Appradio 4 itself does have connections for these (see pic B) but these are only labeled front/rear but don't tell you what's right/left and are only colored red/white. My question is: do the PAC RCA connectors go to the back of the Appradio 4 and how do I know what's left or what's right? And where do the ones from the Appradio 4 wiring harness go to (pic A on the right)? See pic C for the PAC diagram.
A. RCA speaker wires from PAC and speaker wires from Appradio 4 harness: http://i.imgur.com/lS6cfGX.jpg
B. Appradio 4 front/rear outputs: http://i.imgur.com/2LtgI5p.jpg
C. PAC wiring diagram: http://i.imgur.com/Ch7u2He.jpg
D: Current wiring as a whole: http://i.imgur.com/ZJlCyXZ.jpg
2) There are several wires not listed on the PAC or Appradio 4 install manuals, this includes a blue w/ white strip wire labeled SYSTEM REMOTE CONTROL on the Appradio 4 harness and one that comes out of the PAC with same colors, do these just go together? As you can see in pic C the blue with white stripe is not even listed!  :shock:
3) There is also a red wire coming out of Appradio 4 harness and one coming out of PAC, do these go together? As you can see in pic C, PAC lists the wire as "Accessory Output (1 amp)" but on the manual for the Appradio 4 the red wire coming out of the Appradio 4 harness is labeled "To electric terminal controlled by ignition switch (12 V DC ON/OFF). Since I'm a newbie this is throwing me off!
4) There are 4 wires on the PAC labeled "Navigation Outputs" (red/white, green, orange/white, violet/white) - These are listed in pic C, so I figure the orange / white on the Appradio 4 harness is for illumination (am I correct?), The green is listed on PAC as the Reverse Output, does this connect to the violet/white on the harness which is labeled "Reverse Gear Signal Input"??
Also, the red/white on the PAC says it's Parking Break Output -- I'm using a bypass so does this just simply go to the bypass connection with the Appradio 4's parking break connection? Lastly, the purple/white on the PAC says "Vehicle Speed Output" -- I have absolutely no clue where this goes on the Appradio 4 harness?
5) There is a white/black wire coming out of Appradio 4 harness but there is none on the PAC and I have no idea what it's for?
6) I accidentally bought a Metra wiring harness for the car (Metra 70-1729), but noticed that it had an extra orange wire that the harness coming out of the PAC does not, does anyone know what this is for?
Edited Sep 11, 2015 by Saintvale
