Problem "speed calbe is not connected , GPS"
By Nex8000tag · Sep 16, 2015in NEX Series💬 3 posts👁️ 1,180 views
Posted Sep 16, 2015 · 15:26 UTC#1
Hello,
I'm the new owner of a Nex8000 unit and after install it on my highlander 2013, when i use the gps, i have the message that "the speed wire is not collected, the gps will work on hydrid mode" It is because i use the screen bypass of the unit?
Thank you for your time!
Posted Sep 16, 2015 · 23:15 UTC#2
No it means you didn't hook up your VSS wire. Will work fine in simple hybrid, but you get better accuracy by connecting to your vehicle's speed pulse. Especially if you lose GPS signal in tunnels or areas of weak reception.
Posted Sep 16, 2015 · 23:41 UTC#3
Tank you very much!! I appreciate! I will talk with the technician for connect it! So i dont know wich wire it is!
