AVH-4100 w/ MaestroRR NO Bluetooth phone audio
By Natruzork · Sep 21, 2015in NEX Series💬 5 posts👁️ 3,639 views
Posted Sep 21, 2015 · 20:21 UTC#1
Hi guys. I recently installed my AVH-4100 on my GTI mk6 with the iDatalink MaestroRR module. I did the job myself with the instructions froms Crutchfield and everything went OK. Music audio works fine, Carplay works fine on music and phone with Siri, and AppRadio also works well when I tried it.
The problem comes when I try to make calls with the iPhone via Bluetooth (no wires connected, either Carplay or AppRadio). The iPhone seems to pair fine with the AVH4100, since I can see all my contacts and recent calls, but when I dial a number and the call is in progress, no audio comes in or out.
I tried to look for this issue everywhere, but cannot find a solution.
Anyone dealt with this issue? Any suggestion?
Posted Sep 21, 2015 · 21:49 UTC#2
I think there is a setting you need to change to allow bluetooth rather than carplay.  However, calls and audio sound great leaving BT off and using CarPlay with the lightening connection.  I hope that helps.
Posted Sep 21, 2015 · 22:39 UTC#3
No, if you have both Bluetooth and CarPlay set up then the head unit will connect via Bluetooth whenever you do not connect the lightning cable. The problem is something else.
Are there volume settings for Bluetooth that need to be adjusted? I can't remember from memory... If not, I'd "forget" the bluetooth device on both the head unit and iPhone and start again. Good luck.
Posted Sep 24, 2015 · 13:08 UTC#4
if you using maestro check the settings in the radio under OEM settings and make sure bluetooth is on..
Posted Sep 28, 2015 · 16:35 UTC#5
I'm having same issue but on maestro site under firmware it says needs pioneer firmware version 1.08 but the 4100 is still listed as 1.03
