Z1 - Z2 Update & 2 wire bypass
By cgcmgr · Sep 12, 2007in Hacks/Mods💬 5 posts👁️ 1,686 views
Posted Sep 12, 2007 · 18:49 UTC#1
Ok,
Hopefully this will be the last question. I have the Z1 and it's not yet installed. I will do the Z1 to Z2 update via a new drive. However, I will do it AFTER the install to make sure everything works when installed. I want to do the 2 wire bypass also.
Here is what I plan to do, please correct me if I'm wrong.
1. Install the Z1
2. Do the 2-wire Bypass
3. Put the Z2 image on my new hard drive using the sticky http://www.avic411.com/forum/viewtopic.php?t=9446
4. Install the Hard Drive & turn on Z1.
Since the files to create the Z2 image are already bypassed I shouldn't need to anything else.
Hopefully after that I should have a working bypassed Z2
IS THIS CORRECT?
Posted Sep 12, 2007 · 20:56 UTC#2
IS THIS CORRECT?
I believe that you are.... except for this line:
Technically the files aren't bypassed but they are updated so that grounding those two wires will result in a bypassed Z2.
I think what you are thinking is correct, but that line was worded a little weird. But I think you have the right idea in all that.
Posted Sep 12, 2007 · 21:42 UTC#3
IS THIS CORRECT?
Thanks for putting my mind at ease. Now to try it.
Posted Sep 18, 2007 · 02:46 UTC#4
Just to make sure. I have a z2 and have installed the bypass software and grounded the parking wire. But I am getting the "parking lead" error while driving. Does that mean that I have to ground the other wire and follow these instructions?
http://www.sminntech.com/z1flash.html
Posted Sep 18, 2007 · 05:06 UTC#5
Follow these ones:
http://www.sminntech.com/z1flash.html#newbypass
