please, help. AVH-X8650BT
By rustam88 · Oct 08, 2015in Problems/Troubleshooting💬 6 posts👁️ 3,008 views
Posted Oct 08, 2015 · 12:23 UTC#1
please, help. AVH-X8650BT not included. restart restart it again and not working.
Posted Oct 08, 2015 · 12:29 UTC#2
how to download other SDHC flash card
Posted Oct 11, 2015 · 15:38 UTC#3
You haven't explained your problem, or how you got there. I'm going to guess that you tried a hack and the update failed. Here's what I just posted in another thread.:
"when stuck in update mode - and the HU keeps insisting that you insert the correct SD, you need to get into TestMode and delete \USER\SYSTEM\Download\StartKnd.log.
Remove your TestMode SD (or USB stick), and it should restart into regular mode on next power up. "
Hope that helps. I don't usually read the X series forums, so I probably won't be able to follow-up with your progress. I'm sure that someone here can help.
Posted Oct 12, 2015 · 04:47 UTC#4
(8Gb SDHC transent) how to copy? PC set (SDHC)  will not open
Posted Oct 30, 2024 · 03:12 UTC#5
up vote this thread again I've been loopking for AVH-X8650BT software to replace the internal SD card with no hope. Anyone have it can post here? Thanks
