USB2 Grayed Out
By Della · Oct 11, 2015in NEX Series💬 6 posts👁️ 1,126 views
Posted Oct 11, 2015 · 16:13 UTC#1
Could someone please help, I've tried everything I can think of.
Just had a 8100NEX installed at a local shop.
When I connect a USB jump drive to USB1, the AV grey icon goes white and I can access it. But, no matter what I plug into USB2, the HU USB2 icon stays grayed out, I can't access it.
I want iPhone CarPlay on USB1 and a flash drive on USB2, am I missing something?
Edited Oct 11, 2015 by pdclark
Posted Oct 12, 2015 · 22:13 UTC#2
Fixed. Probably a loose connection.
Posted Oct 23, 2015 · 01:39 UTC#3
Did you remember if your phone was charging?  I'm having the same problem.
Posted Oct 23, 2015 · 02:10 UTC#4
Initially, the port was charging, then not. I had the shop pull the unit & check cables. You also need to be sure USB 2 is not set to Android in settings.
Posted Oct 23, 2015 · 11:01 UTC#5
Just want to clarify. So you had to change the usb cable out on usb2 in order for it to start reading devices?
Posted Oct 23, 2015 · 14:26 UTC#6
No. It must have been loose at the HU.
If yours isn't working, check the connections or change the cable.
It will work & does so nicely.
