Appradio sphda120 Europe with US v1.09 firmware
By bravo2zero · Oct 23, 2015in AppRadio, AppRadio 2, AppRadio 3💬 19 posts👁️ 12,510 views
Posted Oct 23, 2015 · 22:27 UTC#1
Well a few weeks back I posted on here will it work if I popped the latest American on a British head unit , I got answers like " don't it will brick your radio ".
I was looking around loads of forums and Facebook groups and nobody seemed to want to do it or answer my question so I just did it.
Well here's the lowdown for anyone thinking of doing it ...... Do it !
I did it !
I followed the regular instruction and it updated and restarted back up no issues ans sporting the 1.09 firmware.
There is zero .... Nothing ... Zilch different to layout or apps , I don't have any US only apps like Pandora included just the stuff I had on with v1.07. All my functions work fine for CarPlay but more stable and vastly quicker. I click on apps in CarPlay and they open before I have chance to remove my finger off the screen , where as before there was 6-10 second delay.
I've used the radio about 11 hours since updated and so far the bugs in 1.07 I was experiencing have gone , soundless playback , pressing skip caused radio to go quiet till you pressed pause and then resumed and the sound went back normal, random crashing back to pioneer screen and rebooting.
I an using iPhone 6 Plus iOS 9.1
To summarise
No bricked radio as I was told
Vast speed improvement
Bugs for me personally have been fixed
Posted Oct 24, 2015 · 12:08 UTC#2
Great news
Edited Oct 24, 2015 by cage911
Posted Oct 25, 2015 · 15:07 UTC#3
I may do this to mine as I have the Europe firmware for my iPhone 6 and I will connect the first time in the car but after that I just won't connect to phone at all for using music . The Bluetooth is fine but the apps are a pain in the ass
Posted Oct 26, 2015 · 09:11 UTC#4
Great! I will try the 1.09 firmware on my European unit today. Hope there will be some Mirrorlink and Android improvements.
Edited Oct 26, 2015 by hilux_hx
Posted Oct 26, 2015 · 19:25 UTC#5
I took the plunge and all seems well. It does feel slightly quicker but that could be a trick of the mind!
Posted Oct 31, 2015 · 10:17 UTC#6
Its been done all the time right from the AppRadio 2 onwards, so surprised you didn't find loads of info. Mind you it has been more by the Android people who go the opposite way in getting rid of the restrictive US firmware, for the EU one. This means you don't need a handbrake bypass for full screen mirroring which is much more common with Android users.
So, if you just use the basic, restrictive Pioneer features then worth looking at.
However, if you have freed up your experience with the likes of AppRadio Unchained on Android, then be warned you will then need a handbrake bypass device if you go from EU to US firmware.
Posted Nov 02, 2015 · 11:49 UTC#7
I have done the update from 1.08 to 1.09 on my EU unit. Works great, but no new features. The US related stuff (Pandora, ...) is not visible. Just like before. That means the US and EU headunits use the same firmware. There have to be some differences in the hardware (solder jumpers, resistors, config eprom or something else) so the firmware can check if it's an EU or US unit.
@400ixl: Even there is no need for an parking brake bypass circuit. Just grounding the parking brake wire seems to work well.
Hoping for an update to get Android Auto!
Edited Nov 02, 2015 by hilux_hx
Posted Nov 09, 2015 · 17:25 UTC#8
I agree with the above. I didn't lose my parking brake wire bypass upgrading either. They will likely be a hardware mod or the USA people would just be doing the EU upgrade to get a proper bypass.
Posted Dec 17, 2015 · 10:15 UTC#9
New firmware 1.11 for AppRadio 4 SPH-DA120! Will try it today on my European Unit (now has 1.09).
Posted Dec 17, 2015 · 14:31 UTC#10
Done. Still fully works with firmware 1.11 on my European unit. Just the bluetooth firmware is 3.21.3 like before. Do the US units have a newer one? A manual update didn't changed this.
Edited Dec 17, 2015 by hilux_hx
Posted Dec 22, 2015 · 20:34 UTC#11
Hi guys !
Did someone have the same issue as i do, when i try to update from 1.08 EU to 1.11 US (or even 1.09 US) it says "No device, try again later" ? I am following the instructions step by step, with the AVIC5000NEX folder at the usb root, so i don't get why it gives me this message.... Any help please :)
Posted Dec 22, 2015 · 21:46 UTC#12
I solved my problem ! If anyone is experiencing the same issue, I tried to update with several usb keys, a 2go Noname, 16go Sandisk, and finally the 4go Verbatim worked for me ;)
Posted Dec 28, 2015 · 18:15 UTC#13
Worked again for me as well. Bluetooth firmware as well
Posted Mar 02, 2016 · 06:25 UTC#15
Well it kind of works on my da120. Now The CarPlay screen looks like it is not centred and is off by half a screen to the left, and half a screen to the top. This means I can't see anything properly and only see a tiny portion of CarPlay screen.
Anyone had this?
Posted Mar 02, 2016 · 13:29 UTC#16
I have the da120 with firmware 1.08. Would there be any benefit from updating to 1.11?
Posted Mar 03, 2016 · 01:30 UTC#17
Updating from 1.08 to 1.11 on my European unit worked like a charm using a 4 GB memorystick! Bluetooth version is still 3.21.30 - also tried a manual update of BT firmware but still same version.
I now experience a slightly faster dashboard when changing menus. I don't see any new features so I guess it's all about bug fixes. The upcoming iOS 9.3 for iPhone promises better CarPlay functionality also so maybe it's not such a bad idea to update the firmware in the radio unit.
Edited Mar 03, 2016 by KimRos
Posted May 26, 2016 · 00:41 UTC#18
Anyone that's done this and upgraded to the US 1.11, is it possible to downgrade back to UK firmware? Although I only see a download link for 1.07 UK firmware?
Also has anyone tried to use android phone with this new update? any better?
Posted Feb 07, 2017 · 17:09 UTC#19
Did someone tried to do the opposite?
I live in Europe and i bought a US hardware. The FM radio bands are different (US: 99.1/99.3/99.5 vs EU: 99.0/99.2/99.4).
So I wanna try fixing it by installing EU firmware on the US hardware but I'm too afraid it will brick my machine.
I've tried searching online and only found this thread.
Someone have experience/insights/information about this?
