Hi
I have update the speedcams in my F40BT from http://www.speedcamupdates.com/ I have a problem i cant see them on the map and i cant find them in the menu to activate them. Any solution ?
Hi
OK i found the reason i must programmed a destination and then the map show the speedcams when you drive to your destination..
Is there any solution so i can see the speedcams without any destination programmed in the map ?
