Need AppRadio v.2.4.0
By Preroll · Nov 09, 2015in AppRadio, AppRadio 2, AppRadio 3💬 6 posts👁️ 2,501 views
Posted Nov 09, 2015 · 01:04 UTC#1
Does anyone still have the .ipa file for v.2.4.0. for iOS?  I have been using v.2.3.0 on an iOS6 jail broken phone for almost three years as it was the only version that a) worked with my X-950, B) allowed me to use App Radio Extensions, and c) allowed some other JB apps to run.  For some reason, Pioneer has magically pushed a kill switch on this app.  When it launches, it crashes.  If I put the phone into airplane mode, then the app stays running but of course does nothing since I need an active connection for Waze, etc.  Once I re-enable cell service, the app crashes.  I have un-installed, re-installed and nada!  When I upgrade to v.2.8.5, it stays running but unfortunately, that version (although it loads on iOS6), will not perform properly on my X-950.  The screen is over zoomed and no buttons work.  I remember v.2.4.0 worked but I don't have it and perhaps that one will still run.  Can anyone direct me to a copy of it?  This has been beyond frustrating!
Posted Nov 09, 2015 · 13:33 UTC#2
There was a 2.5.0 version on this forum. I can upload it later if needed.
I resolved the issue by installing firewall through Cydia and blocking internet for AR. So far it works.
Posted Nov 11, 2015 · 04:57 UTC#3
Yes. Thanks for 2.5.0 if you can.   You had experienced the same issue with AR?  I think they want to force the upgrades for analytics.  Ironically, v.2.9.0 does work with my X-950 but the old compatible apps are not shown because they are too old.  I had to force them on with AppEX and they work fine now.   I have Cydia but not sure which firewall you installed to make that happen.  Can you tell me which one worked for you as I obviously have Cydia as well.
Thanks again.
Posted Nov 13, 2015 · 21:26 UTC#4
sorry for delay
try this
Posted Nov 13, 2015 · 22:19 UTC#5
I found a firewall and managed to get v.2.3.0 as well as v.2.9.0 working.  Thanks!
Posted Feb 07, 2016 · 10:10 UTC#6
Prerolll, do you still have the .ipa file for v.2.3.0 ?
