4100nex firmware update using SD card?
By Fixatruck · Nov 10, 2015in NEX Series💬 3 posts👁️ 3,007 views
Posted Nov 10, 2015 · 22:59 UTC#1
Instructions are written poorly. They state,
Use one of the following:
- USB Flash Drive (for AVIC-5100NEX, AVIC-6100NEX, AVIC-8100NEX and AVH-4100NEX) formatted to FAT32 and 2GB or larger in capacity OR
- MicroSD card (for AVIC-7100NEX, AVIC-8100NEX and AVH-4100NEX) formatted to FAT32 and 2GB or larger in capacity
Either storage device should be blank without any files on them.
Which USB port to use:
IMPORTANT: Only USB Port 1 on your NEX head unit should be used to update the firmware.
.. Now is the USB 1 port only in referance to the USB drive method or is it being assumed that you will connect the SD card into a USB reader?
Can the firmware be installed using the SD card in the SD slot behind the screen?
Thanks.
Posted Nov 11, 2015 · 00:36 UTC#2
They should have added
Which USB port to use if you are using a USB Flash Drive:
I updated my NEX using just the SD card slot behind the screen.  My USB Port 1 is used to power my Chromecast.
Posted Nov 11, 2015 · 07:15 UTC#3
Thank you
