sph-da100 problems with iphone 6
By Peeweebck · Nov 19, 2015in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,610 views
Posted Nov 19, 2015 · 06:23 UTC#1
Hello all hope someone can help as im on the verge of throwing this unit in the bin. I recently bought the unit as it looked really good and exactly what i was after. I upgraded the software to the most up to date for using a lightning cable and bought a apple av adaptor. the bluetooth works fine and if the car has been sat for a few hours it will connect to appradio app no bother but after that it will not connect to appradio if the car has been shut off with phone connected or for short period of time. is there a software downgrade so i can just use a ipod touch with 30 pin connector thanks
Posted Nov 19, 2015 · 14:37 UTC#2
no need to downgrade to use the 30-pin. Just go to settings and select "other" instead of "AV lightning." Before I was disconnecting the phone, disconnect the Bluetooth and turn off all sources.
Posted Nov 21, 2015 · 15:31 UTC#3
Ah so this will allow the iPod button to be pressed as at moment the iPod button is dull and not able to be selected
Posted Nov 21, 2015 · 15:31 UTC#4
