vehicle odbII Bluetooth to 8100 nex
By thejohn-texas · Nov 22, 2015in NEX Series💬 14 posts👁️ 6,499 views
Posted Nov 22, 2015 · 17:44 UTC#1
Was messing with the settings the other day, noticed the vehicle information tile, thought it would link up to a Bluetooth ODBII reader. Ordered one plugged it up, how do I get it to pair, keeps asking to Imput password on the adaptor (not possible) am I even doing this right help would be appreciated, could not find info in the manual on this.......thank you.....
Posted Nov 23, 2015 · 15:37 UTC#2
I think the headunit is only configured to get the info via an iDatalink Maestro, providing the module is compatible with both the headunit and vehicle.
There others more in the know on this issue. Perhaps they will post...
Posted Nov 24, 2015 · 15:45 UTC#3
I've had no luck connecting to my ODBII reader.
Posted Nov 24, 2015 · 20:10 UTC#4
Does the F70DAB or the F77DAB have an OBD2 reader installed?
Posted Jan 07, 2016 · 04:04 UTC#5
Has anyone been able to get this to work? What adapter would I need?
Posted Jan 07, 2016 · 04:19 UTC#6
You can not connect an OBD2 to the deck. Pioneer only supports connection via the Maestro and that is only for cars that support the on screen controls. If you want OBD 2 data we either need to get a custom rom working or you should look at an alpine deck.
Posted Jan 07, 2016 · 04:24 UTC#7
Does the Jeep support on screen via the Maestro?
Posted Jan 07, 2016 · 10:27 UTC#8
Even with iDataLink Maestro RR is not possible to get ODBII reading on the NEX series.
I contacted their support and there is a huge gap between them to make this work.
http://www.12voltdata.com/forum/viewtopic.php?f=318&t=12742&start=15
So basically only the steering wheel controls that are supported right now, but there is another really important observation.
They have 2 products and as far as I understood it works like this:
Maestro RR - If your car sends Steering wheels functions via CANBUS to the radio you must use this one.
Maestro SW - If you car sends restive signals to the radio, you must use this one.
But please do confirm on their webpage http://maestro.idatalink.com/
Posted Apr 30, 2016 · 02:10 UTC#9
Can't you use the wireless OBD II adapter from like PLX or  OBDLink to the iPhone then use the DashCommand app via Carplay?  I know it works with the 5000 supposedly as a option.
Posted May 01, 2016 · 17:27 UTC#10
you can use OBD II adapter for DashCommand, i have it running on my android via MirrorLink.
Posted May 02, 2016 · 04:19 UTC#11
FYI - the 8200 does not supply vehicle info via idatalink OBD II port. Speed / rpm / fuel / temp etc. you can also now see tire pressure ..
Nice upgrade for my 2012 Wrangler..
Posted May 02, 2016 · 06:19 UTC#12
Your post does not make sense with that not in there.
If it does not supply vehicle info via idatalink OBD II port, then how does it supply "Speed / rpm / fuel / temp etc. you can also now see tire pressure"???
Posted May 02, 2016 · 10:39 UTC#13
Wireless OBD II transmitter sent to your phone then linked via iOS carplay to radio.  Google it!  Plenty of videos on Pioneer and Dashcommand working together.
Posted May 02, 2016 · 13:57 UTC#14
Oops - does NOW supply the above..
