HTC & AVIC-D3 Bluetooth Problem
By UR2CLOS3 · Sep 13, 2007in Problems/Troubleshooting💬 4 posts👁️ 969 views
Posted Sep 13, 2007 · 04:50 UTC#1
Hi,
I recently had a AVIC-D3 deck installed on my 2004 Honda Civic with iPod & Bluetooth upgraded. I can't seem to pair my HTC smartphone together with Bluetooth, which was one of the main reasons I had it upgraded because it's hard to dial with the touch screen. I tried pairing it with a search and having it check under Handsfree wireless but it keeps on coming up with "Invaild Device" message.
Is there anyone who had sucessfully pair their HTC?
Posted Sep 13, 2007 · 11:54 UTC#2
Install JetWareMobile (http://www.jetwaremobile.com/) in your PPC and it should work perfectly. It is in mine!
Software is 15$ but you get a 30 day trial
Posted Sep 14, 2007 · 02:40 UTC#3
I didn't have to use the Jetware...at first i did but i just want to know if it would still work if uninstall it. It worked still. I have to pair it without the wireless headset unless you want to listen to music, etc off your phone.
Anyway, clear your blutooth connection on your phone with pioneer. Reestablish your connection. On the setting, once connection has been established, uncheck wireless headset, and make sure Handsfree is turned on or checked. Once that is done, you should be able to connect and register.
Posted Sep 14, 2007 · 10:25 UTC#4
Lucky You! With my PPC6700, it will pair but most of the functions would not work. But with jetware, it is working perfectly
