Hello all, newb here.
I've been lurking for a bit and I'm not very tech savvy with A/V systems. I did an extensive amount of searching here, the owners manual & Google/YouTube for help and still not confident on how to proceed.
I've seen there's updates for the 8000, but only map updates specifically for the 8100. I've read about a 1.03 and 1.08 and see a 1.10 on Pioneer's firmware support page.
When I start the truck, I wait for the nag screen, "OK", then wait for the menu screen and map to load before moving. I haven't connected my VSS wire to the instrument cluster, but the parking brake wire is grounded.
Once I connect my phone via the upper(?) USB socket, *sometimes* I can select music stored on my phone, Pandora, disc or HD radio. Other times, there's no sound on any setting, even though I can see the music progress timer counting. When this occurs, even if I unplug the phone and try to play music on the phone in my hand, there's no sound coming out of it either. Other times, like last night, the phone will emit a solid screeching tone and won't stop until I hard boot it with the home button and lock button depressed at the same time. Other times, the 8100 goes into a loading screen and will reboot itself 2 or 3 times before success.
After that, I can connect it again and everything works, albeit I'm considering throwing the 8100 and the phone in the river in that I'm not going to reboot the phone and the 8100 every time I go somewhere.
I'm currently only using the front two speakers with a Metra wiring kit (the other 4 speakers are defeated) and no amplifier or sub.
TIA to anyone willing to read this and offer suggestions.
