Just in stalled Camera on my D2
By misiek · Sep 13, 2007in Problems/Troubleshooting💬 5 posts👁️ 1,042 views
Posted Sep 13, 2007 · 13:00 UTC#1
so i just installed the pioneer nd-bc2 and everything seems to be working fine.... my only stupid question is should the whole screen be the camera shot because right now only 3/4 of my screen is the rear view shot and 1/4 is the map... is there a setting i have to change or something to make the rearview the entire screen like i see on the d3 or is that not an option on the d2?
also how good is the nite vison on your camera..... i guess i was expeting more visibility at nite then i got...
thanks
Posted Sep 13, 2007 · 16:35 UTC#2
Hook up your reverse wire and it will be full screen when you put the car in reverse. My night vision is good, especially when braking
Posted Sep 13, 2007 · 16:38 UTC#3
ok sounds good thanks
would the reverse cable get hooked up to the lights or a switch?
any suggestions would be great
thanks
Posted Sep 13, 2007 · 19:30 UTC#4
You run the wire back to your tail lights and tap it in to the wire going to one of your reverse bulbs/lights.
Posted Sep 13, 2007 · 19:55 UTC#5
or find it in the wire harness on the drivers side, and test it with a meter. Saves a lot of time
