AppRadio2 iphone6s+iPod classic ?
By dimitracos · Jan 19, 2016in AppRadio, AppRadio 2, AppRadio 3💬 4 posts👁️ 1,671 views
Posted Jan 19, 2016 · 09:48 UTC#1
Hey guys, could you tell if it is possible to make connection this way:  I have DA100 Appradio2 , iPhone6s, iPod classic.
on the 30 pin wire all the time will be connected ipod classic
iPhone6s planned to be connected to apple AV adapter, then hardwire 5v to adapter(lia lightning connector) and then hdmi to headunit.
Actually I need music from  iPod, but apps from iPhone. S how do you think, is that connection possible?
Posted Jan 20, 2016 · 15:12 UTC#2
You can not be used simultaneously.
I put a switch on the power of the pin 30, so as to pass to hdmi without removing the iPod.
We still go to the settings every time.
Posted Jan 21, 2016 · 15:36 UTC#3
actually problem is solved already. I CAN use simultaneously both devices. hardwired 5V power for apple av adapter + regular cable for iPod.
Posted Jan 22, 2016 · 16:23 UTC#4
You can not use both at once.
Edited Jan 22, 2016 by zetaR
