I recently updated the firmware on my 8100 and lost the UK English TTS voices. Is there any way to get them back?
Any help is greatly appreciated.
You can install any available TTS voice again using testmode. Also you can install new maps and other content. http://avic411.com/index.php?/topic/81468-the-avic-development-mod/?p=337784
Did you update your maps? You might have accidentally uninstalled the file during the Naviextras update. I would sync the Nav to a USB and use the Naviextras Toolbox to make sure that speech file is added to the unit. Only thing I can think as to why that TTS file/voice disappeared after you did an update. Just updating the firmware shouldn't have effected the Nav files. If you updated the Nav files separately using the Naviextras tool. Then that might explain it.
Thanks for the responses guys:-
@whatiswhat - I'll wait till I need to do a major map update before undertaking that task and hopefully there will be a video tutorial by then.
@Huddy - I did update my maps and lost the voices, tried your suggestion but could not find them in Naviextras
I believe they are under the ADVANCED menu labeled "other". You can install/uninstall the voices there. Hope you figure it out. GL
Thanks Huddy. Checked and double checked. No uk voices in naviextras I even drilled into all of the available regions
