Hi folks. I'm tentatively planning to use the 4100NEX head unit, but I have some concerns/confusion that I'm hoping folks here can clarify. I'd like to avoid discovering after-the-fact that I cannot use the 4100 for a few specific use cases that are important to me.
I've searched other threads here, and read significant portions of the manual, but some of this may still be redundant. Apologies in advance.
One function that is critical for me is to store my entire music collection offline on local MP3 and/or FLAC files on an SD card. Assume that I use a 64GB SD card that has 50GB of MP3 content stored in 12,000 files arranged in 1100 folders (all below the spec'd limits from Pioneer).
1) after the initial long/painful format-read/indexing, will the format/index data be retained in 4100 non-volatile memory?
2) specifically, after an initial format/index, on subsequent starts of the vehicle, will the SD content be immediately available (no repeat of format/index)??
3) if I move back and forth between HD radio and the SD content, will the SD content be available immediately?
In reading other threads, it seems like some folks have problems w/ large file structures on USB and/or SD while others do not. This particular functionality is VERY important to me. My current Pioneer unit (4400BH) is very annoying in this regard: my USB with 40GB requires a format read EVERY time that I start the car, or switch back from radio or Bluetooth sources. It takes about 3 minutes every time.
I brought the same USB stick to a Pioneer dealer to check out the 4100, and it took over 30 minutes before the 4100 had format/indexed all the files. Further, the dealer demo setup had the "ignition" input to the 4100 hard wired to +12V, so there was no way to simulate an engine on/off cycle.
Next questions are details about AndroidAuto / CarPlay functionality. My primary phone will be a Nexus 5X but I will have passengers w/ iPhones.
Using USB2 for AndroidAuto via Nexus 5X:
4) Can I play audio from the SD card, and simultaneously see Google Maps on the screen via AndroidAuto? Or are the "native" modes of the 4100NEX mutually exclusive to the AndroidAuto mode?
5) Is any "multi-tasking" supported by AndroidAuto? For example, can I listen to NPR (via the NPR One AA app) while simultaneously running Google Maps and seeing it on the screen? Or is AA a one-app-at-a-time scenario only?
6) Can both USB1 and USB2 be used for phone charging? For example, can I run AA from my Nexus 5X over USB2 while my passenger charges their iPhone via the USB1? Or the inverse: can I charge my Nexus on USB2 (AA not running) while my passenger runs CarPlay via iPhone over USB1?
And a couple other questions:
7) USB1 cannot be used for audio or video files via a USB stick, just USB2, correct? But can be used for charging??
8.) Say I play a DVD and route the video over the 4100 composite video output to a large (~27") screen in the back of my van (camping scenario, not driving). The 4100 should output the native 720x480 resolution of the DVD, correct? I assume there is no up-sampling to HD. In this video use case, will the DVD audio be ONLY available on the mini-pin audio output that accompanies the yellow video output on the 4100? Or can I configure the 4100 to send the DVD audio to the standard pre-amp outputs (front/rear/sub)? Basically, when camping, I'd like to play a DVD, sending the video to a large screen, but have the audio come through the normal rear amp/speakers.
Sorry for long first post. Thanks for any insight/guidance in response.
