Iphone 6 & F900BT - Is is possible ?
By Rake · Feb 29, 2016in General💬 1 posts👁️ 1,455 views
Posted Feb 29, 2016 · 14:08 UTC#1
Dear all, sorry for the repeat post (posted in problems and troubleshooting).
I recently got the F900BT model with the intention of using the Iphone with it.
It has the correct interface cable however it will not connect via the 30 pin to Lightening connector (genuine).
I have read that there are problems with this but wanted to ask in case a workaround has been found ?
It ssems that the only way I can use the iphone 6 is via the aux port on the front with AV2 set to video.
Is this really the case or is there a workaround allowing use of the iphone via the cable ?
Many thanks in advance.
Ron.
