step by step please.
whats the easiest way to put back ground pictures to a zz2
See the owners manual pages 100-102 for a step by step. Here is the short version:
Burn a cd-r(w) with a folder called "pictures". Put your 500x240 pixel jpgs in this folder. When you are on the z2 and select the change background image option, you will select 'import from disc'. If your drive is unlocked, you can copy the images as BMP directly to the hard drive.
-G
well the manual tells you step by step...but...
resize your pics to 500x240
stick them in a folder called Pictures
under that folder create a subfolder and call it whatever your little heart desires.......and fill it 100mb worth of junk...or anything that is at least 100mb in size...
now fire up Nero or the likes....
make sure it is not multi session and finalizes the disc after the burn
make sure it's Mode 1 ISO 9660
burn it to a cd-r(what I used at least)
stick the disc in the Avic....
go to your settings menu and where to change the background and splash screen
press from disc....
select picture....hit ok or something like that...and your done...
