GPS takes a long time to display.
By Bear Down · Mar 27, 2016in NEX Series💬 7 posts👁️ 1,796 views
Posted Mar 27, 2016 · 18:40 UTC#1
My gps takes 15-20 seconds to start displaying the map. I'll get the spinning wheel for a while before the maps appear. Sometimes I'll be almost out of my street before it displays. GPS connections show that I'm getting a good signal. Is this normal? My antenna is mounted in the center of my dash under a mesh speaker grill. I've taken off the grill to see if it helps but it's still the same.
Posted Mar 27, 2016 · 19:44 UTC#2
On the first startup yes mine 8100 is the same. But my Android auto hits quick and I use the maps off that feature.
Edited Mar 27, 2016 by JMG_TX
Posted Mar 28, 2016 · 01:09 UTC#3
Yea, that seems about right, I wish it would load at start but it doesn't aways....  You'd think that all the 'standard' features would start at the beginning.... The HD Radio is available as the splash screen is showing...
Posted Mar 05, 2018 · 21:56 UTC#4
Two years later, and this appears to be the same situation. I came to the forum seeking answers on my newly-installed 8200 only to see this disappointing thread. I'm glad you posted the question Bear Down. I was prepared to replace my retained OEM GPS antenna thinking that might be the culprit.
Posted Apr 03, 2018 · 00:44 UTC#5
This unit is far slower than a (audibly crappy) Kenwood Epsilon, their best.  Any system must have current geo-synch data from GPS satellites, so they're asleep, the more time required.  Our problematic BMW 7er was quick to boot, as the system left the GPS 'hot' for some time, keeping data-current, then allowed it to doze off.
Kw had a faster CPU, quickening boot time.
Posted Apr 07, 2018 · 00:58 UTC#6
My 8000 gps boots fast enough.
Posted Apr 07, 2018 · 18:25 UTC#7
my 8100 takes forever for the map to display once you choose it
