FM / HD Radio Album Art Not Showing Up - HELP
By HAZE · Apr 02, 2016in NEX Series💬 4 posts👁️ 1,901 views
Posted Apr 02, 2016 · 22:07 UTC#1
I finally got my 8100NEX installed and was very upset when I put the FM HD Radio on and the album art does not show up. I tried several different stations and it is not working. Is there any way to enable this? What am I missing?
Posted Apr 03, 2016 · 00:49 UTC#2
Unfortunately it's up to the station if they send the artwork... if you see it on another radio and not yours I'm not sure why..... I don't always see art work on the HD startions
Also, make SURE you are looking at stations that show 'Digital HD' not Analog
Posted Apr 03, 2016 · 16:12 UTC#3
I think it might be my crappy stock antenna. I have a 2006 Eclipse and the antenna is built into the rear windshield. Going to try to add an aftermarket antenna and see if that helps. I live right outside NYC and all the stations send artwork. Thanks.
Posted Apr 04, 2016 · 00:29 UTC#4
When you write "... album art does not show up."  Do you mean the Cover Art never shows up or it doesn't always show up?  The reason, I ask is because the images are some times sent once per song, not at all, or sometimes multiple times per song.  I've noticed at times I do not see the Cover Art when I've turned the station on when the song already started.  Anyway, I'm really curious if your aftermarket antenna helps -- please update after your done experimenting.  Thanks.
http://hdradio.com/broadcasters/engineering-support/artist-experience
Edited Apr 04, 2016 by bitmap
