navigation problem
By teeyon · Sep 15, 2007in General💬 5 posts👁️ 1,266 views
Posted Sep 15, 2007 · 01:33 UTC#1
do i need to connect the pink and purple wire on the brain? because the navigation only work when i make turns but it doesn't move when i drive
also is there any way to turn off the day/evening/night dimmer so it'll stay bright?
Posted Sep 26, 2007 · 03:14 UTC#2
you need to hook up all wires nessesary to make this thing work right.
easy
Posted Sep 26, 2007 · 05:40 UTC#3
from my understanding, the reverse and vss arent necessites to be hooked up. the reverse is mainly for a reverse camera and the vss helps w/ the signal. i dont have my vss hooked up on mine and it works just fine. mine is an n1 btw.
Posted Sep 26, 2007 · 19:21 UTC#4
I found a big-time difference in accuracy with VSS hooked up. Much more accurate.
Posted Sep 26, 2007 · 21:55 UTC#5
With the reverse and vss connected on my N3, the navi is dead on when I make turns or back up. I now know what I truly was missing in my old truck with no vss!
