please help nothing but problems
By bigdaddy496 · Apr 05, 2016in NEX Series💬 20 posts👁️ 4,028 views
Posted Apr 05, 2016 · 10:46 UTC#1
i have been trying to put european maps on my american 8100. i installed the script like it said in the thread. then i got nothing but failure to copy errors. i asked and asked and was told i needed to use usb2avic or whatever its called. fine. i found the script after asking and asking and getting no answers. i tried to install it today. now when i am in testmode and tried to copy over the maps and licenses, the igo directory is GONE. guys i really need help. someone please chime in and give me the direction i need because this is irritating.
Posted Apr 06, 2016 · 03:31 UTC#2
I don't have a solution for you, but I do have a question.... Why are you trying to put EU maps on an American unit?
Posted Apr 06, 2016 · 07:20 UTC#3
Because I currently live in germany
Posted Apr 06, 2016 · 07:54 UTC#4
So, what did you do?
If you were using USBtoAvic from an empty USB (with no Backup on it made with AvicToUsb), then yes, your IGO folder is deleted.
Look at the scripts to understand what they do. It's simple deleting, copying and adjust the file attributes, no rocket science.
Try to find a backup of the IGO-Folder if you have none (you should have.., i have only F60/8000NEX files), or simply buy a F70 with working European maps.
Posted Apr 06, 2016 · 16:53 UTC#5
Can i make a Igo folder with everything in it on the usb and then use usbavic to restore the igo that was deleted?
Posted Apr 06, 2016 · 16:53 UTC#6
Posted Apr 06, 2016 · 20:00 UTC#7
If you have a valid copy of an IGO folder, yes.
The USBtoAvic does only delete the IGO folder on the unit, copy the folder from the USB to the unit and apply the attributes.
Posted Apr 06, 2016 · 23:36 UTC#8
ok, so what i am going to do is make an igo folder on the usb, and inside of it make all the same folders as the unit, and put the files i was trying to install into those corresponding files. i should be ok then right?
Posted Apr 07, 2016 · 10:22 UTC#9
Yes. Normal way:
AvicToUSB: makes a copy of your IGO folder from the device to the USB.
Then you can chance the files you want to.
E.g. for a new map replacing the content of
/igo/content/building/
/igo/content/map/
/igo/content/poi/
/igo/license/
The use USBtoAvic to copy your new IGO folder from the USB to the unit. The script will completly replace the IGO folder, so every needed file must be on the USB (like /igo/ux/* ..), not only the new map files.
Posted Apr 07, 2016 · 10:25 UTC#10
Ok but what were the original files? I got the image files someone uploaded but they are all Linux based. If they had some sort of emulator I could just pull the files from those.
Posted Apr 07, 2016 · 18:10 UTC#11
Here is a list of files in my IGO folder (F60dab, original european 13q2). May look slightly different on a 8100NEX
insgesamt 24K
drwxrwxrwx 14 ch_vbox ch_vbox 4,0K Feb 25 12:29 content
-rwxrwxrwx  1   10016   10016   32 Feb 24 16:04 device_checksum.md5
drwxrwxrwx  3 ch_vbox ch_vbox 4,0K Feb 25 14:38 license
drwxrwxrwx  3   10016   10016 4,0K Feb 24 11:38 privdocs
drwxrwxrwx  2   10016   10016 4,0K Jan  1  2014 screenshots
drwxrwxrwx  2   10016   10016 4,0K Feb 24 11:25 ux
./content:
insgesamt 440K
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Mär 21  2014 building
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Mär 21  2014 car
-rwxrwxrwx 1   10016   10016 386K Dez 17  2013 copy.db
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Feb 25 12:25 dem
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Mär 21  2014 global_cfg
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Feb 24 11:25 lang
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Feb 25 12:25 map
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Mär 21  2014 poi
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Mär 21  2014 scheme
drwxrwxrwx 2   10016   10016 4,0K Okt  3  2014 speedcam
drwxrwxrwx 2 ch_vbox ch_vbox 4,0K Mär 21  2014 tmc
drwxrwxrwx 3   10016   10016 4,0K Feb 25 12:24 userdata
drwxrwxrwx 2 ch_vbox ch_vbox 8,0K Feb 25 12:25 voice
./content/building:
insgesamt 227M
-rwxrwxrwx 1 ch_vbox ch_vbox 2,0M Sep  3  2013 Austria.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,4M Sep  3  2013 Austria.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 3,7M Sep  3  2013 Belgium.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 4,4M Sep  3  2013 Belgium.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 264K Sep  3  2013 BosniaHrz.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 473K Sep  3  2013 Bulgaria.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 798K Sep  3  2013 Bulgaria.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,5M Sep  3  2013 Croatia.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 827K Sep  3  2013 Croatia.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 2,5M Sep  3  2013 CzechRep.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,2M Sep  3  2013 CzechRep.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 550K Sep  3  2013 Denmark.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,8M Sep  3  2013 Denmark.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 216K Sep  3  2013 Estonia.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 702K Sep  3  2013 Estonia.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 530K Sep  3  2013 Finland.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,4M Sep  3  2013 Finland.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox  14M Sep  3  2013 France.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox  14M Sep  3  2013 France.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 173K Sep  3  2013 FYROM.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 9,9M Sep  3  2013 Germany.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox  36M Sep  3  2013 Germany.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,1M Sep  3  2013 Greece.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,2M Sep  3  2013 Greece.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 2,1M Sep  3  2013 Hungary.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 3,0M Sep  3  2013 Hungary.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,3M Sep  3  2013 Ireland.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,2M Sep  3  2013 Ireland.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 5,7M Sep  3  2013 Italy.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox  11M Sep  3  2013 Italy.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 173K Sep  3  2013 Kosovo.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 512K Sep  3  2013 Latvia.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 854K Sep  3  2013 Latvia.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 105K Sep  3  2013 Liechtenstein.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 266K Sep  3  2013 Lithuania.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 741K Sep  3  2013 Lithuania.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 605K Sep  3  2013 Luxembourg.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 992K Sep  3  2013 Luxembourg.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 2,7M Sep  3  2013 Netherlands.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 5,2M Sep  3  2013 Netherlands.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 784K Sep  3  2013 Norway.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,2M Sep  3  2013 Norway.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 2,8M Sep  3  2013 Poland.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 4,3M Sep  3  2013 Poland.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,6M Sep  3  2013 Portugal.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 3,1M Sep  3  2013 Portugal.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,4M Sep  3  2013 Romania.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,3M Sep  3  2013 Romania.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 640K Sep  3  2013 Serbia.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 636K Sep  3  2013 Slovakia.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,6M Sep  3  2013 Slovakia.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 2,0M Sep  3  2013 Slovenia.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,6M Sep  3  2013 Slovenia.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 7,3M Sep  3  2013 Spain.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox  12M Sep  3  2013 Spain.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,4M Sep  3  2013 Sweden.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,7M Sep  3  2013 Sweden.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 887K Sep  3  2013 Switzerland.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 2,8M Sep  3  2013 Switzerland.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 7,0M Sep  3  2013 Turkey.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 3,1M Sep  3  2013 Turkey.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,4M Sep  3  2013 Ukraine.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,6M Sep  3  2013 Ukraine.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox  12M Sep  3  2013 UnitedKingdom.3dc
-rwxrwxrwx 1 ch_vbox ch_vbox  13M Sep  3  2013 UnitedKingdom.3dl
-rwxrwxrwx 1 ch_vbox ch_vbox  60K Sep  3  2013 Vatican.3dl
./content/car:
insgesamt 384K
-rwxrwxrwx 1 ch_vbox ch_vbox 32K Feb  5  2009 Car.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 45K Feb  5  2009 Flying_Carpet.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 31K Feb  5  2009 Hot_Rod_Red.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 29K Feb  5  2009 Hot_Rod_Silver.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 30K Feb  5  2009 Limousine_Silver.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 36K Feb  5  2009 Minivan.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 32K Mär  3  2009 Off-Road.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 38K Feb 14  2011 Race_Car.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 35K Feb  5  2009 Sports_Car.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 27K Feb  5  2009 Station_Wagon.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 33K Feb  5  2009 Tank.zip
./content/dem:
insgesamt 240M
-rwxrwxrwx 1 ch_vbox ch_vbox 2,8M Okt 13  2008 Africa.dem
-rwxrwxrwx 1 ch_vbox ch_vbox 8,5M Sep 20  2012 Eurasia.dem
-rwxrwxrwx 1 ch_vbox ch_vbox 221M Sep 20  2012 Europe.dem
-rwxrwxrwx 1 ch_vbox ch_vbox 4,4M Nov  3  2008 North_America.dem
-rwxrwxrwx 1 ch_vbox ch_vbox 1,4M Okt 13  2008 Oceania.dem
-rwxrwxrwx 1   10016   10016 2,1M Feb 25 12:25 South_America.dem
-rwxrwxrwx 1   10016   10016   32 Feb 25 12:25 South_America.dem.md5
./content/global_cfg:
insgesamt 7,6M
-rwxrwxrwx 1 ch_vbox ch_vbox 7,6M Jan 13  2014 global_cfg.zip
./content/lang:
insgesamt 5,1M
-rwxrwxrwx 1 10016 10016 161K Okt  6  2015 Lang_Arabic.zip
-rwxrwxrwx 1 10016 10016 171K Okt  6  2015 Lang_Bulgarian.zip
-rwxrwxrwx 1 10016 10016 155K Okt  6  2015 Lang_Catalan.zip
-rwxrwxrwx 1 10016 10016 168K Okt  6  2015 Lang_Croatian.zip
-rwxrwxrwx 1 10016 10016 168K Okt  6  2015 Lang_Czech.zip
-rwxrwxrwx 1 10016 10016 156K Okt  6  2015 Lang_Danish.zip
-rwxrwxrwx 1 10016 10016 160K Okt  6  2015 Lang_Dutch-be.zip
-rwxrwxrwx 1 10016 10016 167K Okt  6  2015 Lang_Dutch-nl.zip
-rwxrwxrwx 1 10016 10016 151K Okt  6  2015 Lang_English-uk.zip
-rwxrwxrwx 1 10016 10016 151K Okt  6  2015 Lang_Estonian.zip
-rwxrwxrwx 1 10016 10016 166K Okt  6  2015 Lang_Finnish.zip
-rwxrwxrwx 1 10016 10016 173K Okt  6  2015 Lang_French.zip
-rwxrwxrwx 1 10016 10016 188K Okt  6  2015 Lang_German.zip
-rwxrwxrwx 1 10016 10016 183K Okt  6  2015 Lang_Greek.zip
-rwxrwxrwx 1 10016 10016 154K Okt  6  2015 Lang_Hebrew.zip
-rwxrwxrwx 1 10016 10016 170K Okt  6  2015 Lang_Hungarian.zip
-rwxrwxrwx 1 10016 10016 173K Okt  6  2015 Lang_Italian.zip
-rwxrwxrwx 1 10016 10016 158K Okt  6  2015 Lang_Latvian.zip
-rwxrwxrwx 1 10016 10016 158K Okt  6  2015 Lang_Lithuanian.zip
-rwxrwxrwx 1 10016 10016 164K Okt  6  2015 Lang_Norwegian.zip
-rwxrwxrwx 1 10016 10016 169K Okt  6  2015 Lang_Polish.zip
-rwxrwxrwx 1 10016 10016 161K Okt  6  2015 Lang_Portuguese.zip
-rwxrwxrwx 1 10016 10016 164K Okt  6  2015 Lang_Romanian.zip
-rwxrwxrwx 1 10016 10016 185K Okt  6  2015 Lang_Russian.zip
-rwxrwxrwx 1 10016 10016 158K Okt  6  2015 Lang_Serbian.zip
-rwxrwxrwx 1 10016 10016 170K Okt  6  2015 Lang_Slovak.zip
-rwxrwxrwx 1 10016 10016 163K Okt  6  2015 Lang_Slovenian.zip
-rwxrwxrwx 1 10016 10016 172K Okt  6  2015 Lang_Spanish.zip
-rwxrwxrwx 1 10016 10016 159K Okt  6  2015 Lang_Swedish.zip
-rwxrwxrwx 1 10016 10016 166K Okt  6  2015 Lang_Turkish.zip
-rwxrwxrwx 1 10016 10016 175K Okt  6  2015 Lang_Ukrainian.zip
./content/map:
insgesamt 1,9G
-rwxrwxrwx 1 ch_vbox ch_vbox 3,4M Jul 19  2013 Albania.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  96K Sep  4  2013 Andorra.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  40M Jul 19  2013 Austria.fbl
-rwxrwxrwx 1   10016   10016 9,0M Feb 25 12:25 Basemap.fbl
-rwxrwxrwx 1   10016   10016   32 Feb 25 12:25 Basemap.fbl.md5
-rwxrwxrwx 1 ch_vbox ch_vbox 262K Jul 19  2013 Belarus.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  19M Jul 19  2013 Belgium.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 5,6M Jul 19  2013 BosniaHrz.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  17M Jul 19  2013 Bulgaria.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  17M Jul 19  2013 Croatia.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  45M Jul 19  2013 CzechRep.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  14M Jul 19  2013 CzechRep.fpa
-rwxrwxrwx 1 ch_vbox ch_vbox  19M Jul 19  2013 Denmark.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  15M Jul 19  2013 Estonia.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  45M Okt 18  2013 EuropeEasy.hnr
-rwxrwxrwx 1 ch_vbox ch_vbox  43M Okt 18  2013 EuropeFastest.hnr
-rwxrwxrwx 1 ch_vbox ch_vbox  42M Okt 18  2013 EuropeGreen.hnr
-rwxrwxrwx 1 ch_vbox ch_vbox  49M Okt 18  2013 EuropeShortest.hnr
-rwxrwxrwx 1 ch_vbox ch_vbox  87M Jul 19  2013 Finland.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 234M Sep  4  2013 France.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 3,1M Jul 19  2013 FYROM.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 171M Jul 19  2013 Germany.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  14K Sep  4  2013 Gibraltar.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  45M Dez  4  2013 Greece.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  22M Jul 19  2013 Hungary.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  13M Jul 19  2013 Iceland.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  15M Jul 19  2013 Ireland.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 133M Jul 19  2013 Italy.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,1M Jul 19  2013 Kosovo.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  15M Jul 19  2013 Latvia.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 102K Jul 19  2013 Liechtenstein.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  13M Jul 19  2013 Lithuania.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 2,0M Jul 19  2013 Luxembourg.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 587K Jul 19  2013 Malta.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 297K Jul 19  2013 Moldova.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  40K Sep  4  2013 Monaco.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 1,3M Jul 19  2013 Montenegro.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  32M Okt 17  2013 Netherlands.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  37M Jul 19  2013 Norway.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  65M Jul 19  2013 Poland.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  53M Jul 19  2013 Portugal.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  19M Jul 19  2013 Romania.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  68K Jul 19  2013 SanMarino.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 7,1M Jul 19  2013 Serbia.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  21M Jul 19  2013 Slovakia.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 6,7M Jul 19  2013 Slovakia.fpa
-rwxrwxrwx 1 ch_vbox ch_vbox  11M Jul 19  2013 Slovenia.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 121M Sep  4  2013 Spain.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  65M Jul 19  2013 Sweden.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  27M Jul 19  2013 Switzerland.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  62M Jul 19  2013 Turkey.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 122M Jul 19  2013 Ukraine.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox  23M Jul 19  2013 Ukraine.fpa
-rwxrwxrwx 1 ch_vbox ch_vbox  91M Sep  9  2013 UnitedKingdom.fbl
-rwxrwxrwx 1 ch_vbox ch_vbox 6,6K Jul 19  2013 Vatican.fbl
./content/poi:
insgesamt 646M
-rwxrwxrwx 1 ch_vbox ch_vbox 434K Sep 18  2013 Albania.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 5,7M Jul 17  2013 Austria_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 6,1M Sep 18  2013 Austria.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  18K Sep 18  2013 Belarus.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  12M Jul 17  2013 Belgium_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 6,3M Sep 18  2013 Belgium.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 780K Sep 18  2013 BosniaHrz.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 3,6M Sep 18  2013 Bulgaria.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 357K Jul 17  2013 Croatia_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 2,6M Sep 18  2013 Croatia.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 1,4M Jul 17  2013 CzechRep_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 6,8M Sep 18  2013 CzechRep.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  11M Jul 17  2013 Denmark_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 5,6M Sep 18  2013 Denmark.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 1,1M Sep 18  2013 Estonia.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 3,3M Jul 17  2013 Finland_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 8,1M Sep 18  2013 Finland.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  41M Jul 17  2013 France_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  35M Sep 18  2013 France.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 265K Sep 18  2013 FYROM.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  52M Jul 17  2013 Germany_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  43M Sep 18  2013 Germany.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  11M Sep 18  2013 Greece.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 4,7M Jul 17  2013 Hungary_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 7,7M Sep 18  2013 Hungary.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 303K Sep 18  2013 Iceland.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 1,4M Jul 17  2013 Ireland_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 1,3M Sep 18  2013 Ireland.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  35M Jul 17  2013 Italy_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  20M Sep 18  2013 Italy.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 947K Sep 18  2013 Latvia.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 868K Sep 18  2013 Lithuania.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 210K Jul 17  2013 Luxembourg_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 648K Sep 18  2013 Luxembourg.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 414K Sep 18  2013 Malta.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  13K Sep 18  2013 Moldova.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 325K Sep 18  2013 Montenegro.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  22M Jul 17  2013 Netherlands_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 8,6M Sep 18  2013 Netherlands.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 4,6M Jul 17  2013 Norway_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 2,9M Sep 18  2013 Norway.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  39M Jul 17  2013 Poland_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  12M Sep 18  2013 Poland.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 5,9M Jul 17  2013 Portugal_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 5,2M Sep 18  2013 Portugal.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 8,1M Sep 18  2013 Romania.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 1,8M Sep 18  2013 Serbia.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 3,0M Jul 17  2013 Slovakia_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 4,2M Sep 18  2013 Slovakia.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 1,2M Jul 17  2013 Slovenia_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 2,2M Sep 18  2013 Slovenia.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  37M Jul 17  2013 Spain_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  20M Sep 18  2013 Spain.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  15M Jul 17  2013 Sweden_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 7,3M Sep 18  2013 Sweden.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 6,6M Jul 17  2013 Switzerland_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox 6,9M Sep 18  2013 Switzerland.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  38M Sep 18  2013 Turkey.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  19M Sep 18  2013 Ukraine.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  11M Jul 17  2013 UnitedKingdom_ext.poi
-rwxrwxrwx 1 ch_vbox ch_vbox  40M Sep 18  2013 UnitedKingdom.poi
./content/scheme:
insgesamt 48K
-rwxrwxrwx 1 ch_vbox ch_vbox 2,8K Mai 29  2012 Easy-Day.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 2,5K Mai 29  2012 Easy-Night.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 2,8K Mai 29  2012 Jove-Day.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 2,5K Mai 29  2012 Jove-Night.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 3,5K Jul 12  2012 Minimal.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 2,8K Mai 29  2012 Old-School-Day.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 2,5K Mai 29  2012 Old-School-Night.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 4,8K Jul 12  2012 Silver-Day.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 3,0K Jul 12  2012 Silver-Night.zip
-rwxrwxrwx 1 ch_vbox ch_vbox 4,3K Jul 12  2012 Topo.zip
./content/speedcam:
insgesamt 0
-rwxrwxrwx 1 10016 10016 0 Okt  3  2014 SpeedcamUpdates.spud
./content/tmc:
insgesamt 16K
-rwxrwxrwx 1 ch_vbox ch_vbox 1,2K Jun  8  2011 Finland-MediamobileNordic.tmc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,3K Mär  2  2010 France-ViaMichelin.tmc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,2K Jun  8  2011 Sweden-MediamobileNordic.tmc
-rwxrwxrwx 1 ch_vbox ch_vbox 1,3K Jun  2  2011 UnitedKingdom-ITIS.tmc
./content/userdata:
insgesamt 4,0K
drwxrwxrwx 2 10016 10016 4,0K Feb 25 12:25 poi
./content/userdata/poi:
insgesamt 2,0M
-rwxrwxrwx 1 10016 10016    6 Feb 25 12:25 D-LPG-24H.kix
-rwxrwxrwx 1 10016 10016 2,0M Feb 25 12:24 D-LPG-24H.kml
-rwxrwxrwx 1 10016 10016   32 Feb 25 12:24 D-LPG-24H.kml.md5
-rwxrwxrwx 1 10016 10016   12 Feb 25 12:25 D-LPG-24H.kns
./content/voice:
insgesamt 183M
-rwxrwxrwx 1 10016 10016  5,0M Feb 25 12:24 Voice_Ara-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Ara-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  4,9M Feb 25 12:24 Voice_Ara-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Ara-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,0M Feb 25 12:24 Voice_Bul-f2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Bul-f2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,1M Feb 25 12:24 Voice_Bul-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Bul-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,2M Feb 25 12:24 Voice_Cat-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Cat-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,2M Feb 25 12:24 Voice_Cat-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Cat-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  824K Feb 25 12:24 Voice_Cro-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Cro-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  4,0M Feb 25 12:24 Voice_Cze-f3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Cze-f3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  4,0M Feb 25 12:24 Voice_Cze-m4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Cze-m4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  4,2M Feb 25 12:24 Voice_Dan-f2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Dan-f2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  5,2M Feb 25 12:24 Voice_Dan-m4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Dan-m4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  5,8M Feb 25 12:24 Voice_Deu-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Deu-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  6,2M Feb 25 12:24 Voice_Deu-m4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Deu-m4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,9M Feb 25 12:24 Voice_Dut-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Dut-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,9M Feb 25 12:24 Voice_Dut-m4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Dut-m4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,3M Feb 25 12:24 Voice_Eng-uk-f3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Eng-uk-f3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,5M Feb 25 12:24 Voice_Eng-uk-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Eng-uk-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,1M Feb 25 12:24 Voice_Esp-f3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Esp-f3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,2M Feb 25 12:24 Voice_Esp-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Esp-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,5M Feb 25 12:24 Voice_Est-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Est-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,8M Feb 25 12:24 Voice_Est-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Est-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,5M Feb 25 12:24 Voice_Fin-f3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Fin-f3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,4M Feb 25 12:24 Voice_Fin-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Fin-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  5,4M Feb 25 12:24 Voice_Fle-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Fle-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  5,3M Feb 25 12:24 Voice_Fle-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Fle-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,5M Feb 25 12:24 Voice_Fra-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Fra-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,6M Feb 25 12:24 Voice_Fra-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Fra-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,1M Feb 25 12:24 Voice_Gre-f11-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Gre-f11-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,0M Feb 25 12:24 Voice_Gre-m11-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Gre-m11-lua.zip.md5
-rwxrwxrwx 1 10016 10016  842K Feb 25 12:24 Voice_Hb-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hb-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,1M Feb 25 12:24 Voice_Hb-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hb-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  699K Feb 25 12:24 Voice_Hun-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hun-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,7M Feb 25 12:24 Voice_Hun-f2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hun-f2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,7M Feb 25 12:24 Voice_Hun-m11-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hun-m11-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,9M Feb 25 12:24 Voice_Hun-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hun-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,8M Feb 25 12:24 Voice_Hun-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Hun-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,0M Feb 25 12:24 Voice_Ita-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Ita-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  915K Feb 25 12:24 Voice_Ita-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Ita-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,9M Feb 25 12:24 Voice_Lit-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Lit-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,0M Feb 25 12:24 Voice_Lit-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Lit-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,8M Feb 25 12:24 Voice_Lva-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Lva-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,7M Feb 25 12:24 Voice_Lva-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Lva-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016 1014K Feb 25 12:24 Voice_Nor-f31-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Nor-f31-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,1M Feb 25 12:24 Voice_Nor-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Nor-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,2M Feb 25 12:24 Voice_Pol-f3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Pol-f3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,3M Feb 25 12:24 Voice_Pol-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Pol-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,4M Feb 25 12:25 Voice_Por-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:24 Voice_Por-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,5M Feb 25 12:25 Voice_Por-m4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Por-m4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,1M Feb 25 12:25 Voice_Rom-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Rom-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  1,1M Feb 25 12:25 Voice_Rom-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Rom-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,3M Feb 25 12:25 Voice_Rus-f3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Rus-f3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,7M Feb 25 12:25 Voice_Rus-m3-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Rus-m3-lua.zip.md5
-rwxrwxrwx 1 10016 10016  6,0M Feb 25 12:25 Voice_Slo-f2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Slo-f2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  5,8M Feb 25 12:25 Voice_Slo-m2-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Slo-m2-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,0M Feb 25 12:25 Voice_Srb-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Srb-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,3M Feb 25 12:25 Voice_Srb-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Srb-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,7M Feb 25 12:25 Voice_Svn-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Svn-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,8M Feb 25 12:25 Voice_Svn-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Svn-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  4,7M Feb 25 12:25 Voice_Swe-f4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Swe-f4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  4,8M Feb 25 12:25 Voice_Swe-m4-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Swe-m4-lua.zip.md5
-rwxrwxrwx 1 10016 10016  118K Feb 25 12:25 Voice_TTS-android-dan-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-dan-lua.zip.md5
-rwxrwxrwx 1 10016 10016  124K Feb 25 12:25 Voice_TTS-android-deu-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-deu-lua.zip.md5
-rwxrwxrwx 1 10016 10016  121K Feb 25 12:25 Voice_TTS-android-dut-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-dut-lua.zip.md5
-rwxrwxrwx 1 10016 10016  132K Feb 25 12:25 Voice_TTS-android-eng-uk-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-eng-uk-lua.zip.md5
-rwxrwxrwx 1 10016 10016  141K Feb 25 12:25 Voice_TTS-android-eng-us-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-eng-us-lua.zip.md5
-rwxrwxrwx 1 10016 10016  158K Feb 25 12:25 Voice_TTS-android-esp-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-esp-lua.zip.md5
-rwxrwxrwx 1 10016 10016  125K Feb 25 12:25 Voice_TTS-android-fra-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-fra-lua.zip.md5
-rwxrwxrwx 1 10016 10016  139K Feb 25 12:25 Voice_TTS-android-ita-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-ita-lua.zip.md5
-rwxrwxrwx 1 10016 10016  123K Feb 25 12:25 Voice_TTS-android-pol-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-pol-lua.zip.md5
-rwxrwxrwx 1 10016 10016  123K Feb 25 12:25 Voice_TTS-android-por-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-por-lua.zip.md5
-rwxrwxrwx 1 10016 10016  126K Feb 25 12:25 Voice_TTS-android-tur-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_TTS-android-tur-lua.zip.md5
-rwxrwxrwx 1 10016 10016 1016K Feb 25 12:25 Voice_Tur-f21-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Tur-f21-lua.zip.md5
-rwxrwxrwx 1 10016 10016  2,1M Feb 25 12:25 Voice_Tur-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Tur-m1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,4M Feb 25 12:25 Voice_Ukr-f1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Ukr-f1-lua.zip.md5
-rwxrwxrwx 1 10016 10016  3,6M Feb 25 12:25 Voice_Ukr-m1-lua.zip
-rwxrwxrwx 1 10016 10016    32 Feb 25 12:25 Voice_Ukr-m1-lua.zip.md5
./license:
insgesamt 24K
-rwxrwxrwx 1   10016   10016  264 Feb 25 12:45 device.nng
-rwxrwxrwx 1   10016   10016 1,4K Feb 24 15:35 Language_Recovery_Pack_For_Pioneer.lyc
-rwxrwxrwx 1   10016   10016 3,1K Feb 24 15:35 Pioneer_maps_for_Europe_SKU_2004677_FACTORY_PKG_2013_Q2.lyc
-rwxrwxrwx 1   10016   10016 3,2K Nov 27  2014 Pioneer_NF_FEU_13Q2_NQ_ExtPOI_AP_TMC_3D_DEM_HNR_TTS_JV_CAR_CS_High_NX263A.lyc
-rwxrwxrwx 1 ch_vbox ch_vbox 3,1K Feb 16  2014 Pioneer_Primo_FEU_13Q2_NQ_ExtPOI_AP_TMC_3D_DEM_HNR_TTS_JV_CAR_CS_High_NX263_3.lyc
drwxrwxrwx 3   10016   10016 4,0K Jan  1  2014 server_configs
./license/server_configs:
insgesamt 4,0K
drwxrwxrwx 2 10016 10016 4,0K Jan  1  2014 www.naviextras.com
./license/server_configs/www.naviextras.com:
insgesamt 0
./privdocs:
insgesamt 4,0K
drwxrwxrwx 2 10016 10016 4,0K Feb 24 11:38 NewsCenter
./privdocs/NewsCenter:
insgesamt 0
./screenshots:
insgesamt 0
./ux:
insgesamt 4,8M
-rwxrwxrwx 1 10016 10016  14K Nov  6 06:46 address_search_classic.zip
-rwxrwxrwx 1 10016 10016 9,8K Nov  6 06:46 appsandtools.zip
-rwxrwxrwx 1 10016 10016  21K Nov  6 06:46 connected_error_handling.zip
-rwxrwxrwx 1 10016 10016 3,2K Nov  6 06:46 connected_settings.zip
-rwxrwxrwx 1 10016 10016 4,7K Nov  6 06:46 device.zip
-rwxrwxrwx 1 10016 10016 1,1M Nov  6 06:46 driveralerts.zip
-rwxrwxrwx 1 10016 10016 9,7K Nov  6 06:46 favorites_search.zip
-rwxrwxrwx 1 10016 10016  17K Nov  6 06:46 fuel_consumption.zip
-rwxrwxrwx 1 10016 10016  30K Nov  6 06:46 fuel_prices.zip
-rwxrwxrwx 1 10016 10016  19K Nov  6 06:46 grid_menu_layout.zip
-rwxrwxrwx 1 10016 10016 2,0K Nov  6 06:46 guidance_extras.zip
-rwxrwxrwx 1 10016 10016  11K Nov  6 06:46 help.zip
-rwxrwxrwx 1 10016 10016  77K Nov  6 06:46 hwydrive.zip
-rwxrwxrwx 1 10016 10016  51K Nov  6 06:46 iqs.zip
-rwxrwxrwx 1 10016 10016 466K Nov  6 06:46 junctionview.zip
-rwxrwxrwx 1 10016 10016  11K Nov  6 06:46 local_search.zip
-rwxrwxrwx 1 10016 10016 6,0K Nov  6 06:46 mapcustom.zip
-rwxrwxrwx 1 10016 10016  57K Nov  6 06:46 navfusion_client.zip
-rwxrwxrwx 1 10016 10016 6,4K Nov  6 06:46 naviextras.zip
-rwxrwxrwx 1 10016 10016 406K Nov  6 06:46 navtools.zip
-rwxrwxrwx 1 10016 10016  14K Nov  6 06:46 notifications.zip
-rwxrwxrwx 1 10016 10016  26K Nov  6 06:46 online_parking.zip
-rwxrwxrwx 1 10016 10016 1,8K Nov  6 06:46 pioneer_au.zip
-rwxrwxrwx 1 10016 10016 1,8K Nov  6 06:46 pioneer_br.zip
-rwxrwxrwx 1 10016 10016 1,1K Nov  6 06:46 pioneer_eu.zip
-rwxrwxrwx 1 10016 10016 1,3K Nov  6 06:46 pioneer_hu.zip
-rwxrwxrwx 1 10016 10016 9,6K Nov  6 06:46 pioneer_id.zip
-rwxrwxrwx 1 10016 10016 1,7M Nov  6 06:46 pioneer_skin.zip
-rwxrwxrwx 1 10016 10016 1,8K Nov  6 06:46 pioneer_uc.zip
-rwxrwxrwx 1 10016 10016 1023 Nov  6 06:46 pioneer_uw.zip
-rwxrwxrwx 1 10016 10016  13K Nov  6 06:46 pioneer.zip
-rwxrwxrwx 1 10016 10016  13K Nov  6 06:46 poi_search.zip
-rwxrwxrwx 1 10016 10016 4,9K Nov  6 06:46 safety.zip
-rwxrwxrwx 1 10016 10016  25K Nov  6 06:46 smartnavi.zip
-rwxrwxrwx 1 10016 10016  20K Nov  6 06:46 speedcam.zip
-rwxrwxrwx 1 10016 10016 5,8K Nov  6 06:46 the_skin_grid_menu_layout.zip
-rwxrwxrwx 1 10016 10016 4,3K Nov  6 06:46 tmc_online.zip
-rwxrwxrwx 1 10016 10016 344K Nov  6 06:46 tmc.zip
-rwxrwxrwx 1 10016 10016 3,9K Nov  6 06:46 tracking.zip
-rwxrwxrwx 1 10016 10016 172K Nov  6 06:46 triplog.zip
-rwxrwxrwx 1 10016 10016 2,7K Nov  6 06:46 ttspro.zip
-rwxrwxrwx 1 10016 10016 9,4K Nov  6 06:46 user_data_sync.zip
-rwxrwxrwx 1 10016 10016 8,1K Nov  6 06:46 user_profiles.zip
-rwxrwxrwx 1 10016 10016  70K Nov  6 06:46 vehicle_selection.zip
-rwxrwxrwx 1 10016 10016  17K Nov  6 06:46 weather.zip
Posted Apr 08, 2016 · 01:51 UTC#12
holy crap im missing a lot of stuff
is there anyway i can grab a copy of yours? i basicall have the maps, buildings, one dem file (europe), phoneme and poi
Posted Apr 08, 2016 · 02:30 UTC#13
Sorry to hijack, what is the phoneme folder for?
Posted Apr 08, 2016 · 02:46 UTC#14
Phone numbers of poi? I think?
Posted Apr 08, 2016 · 13:17 UTC#15
I've uploaded the content of my flash-USB without igo/content/map, buildings and poi.
Copy the content to a USB, copy your map-files to igo/content and try. Scripts are already inside.
But, since its from a f60/8000nex it may not work or cause weired issues on your 8100.
https://onedrive.live.com/redir?resid=77B46B8063BA3D82!120&authkey=!APfw_VlTCPUdtq0&ithint=file%2czip
As far as i know the phoneme files are for the correct pronounciation of text-to-speech for the different countries. So, if driving in France with a german language setting, the street names will be pronounced in a french way.
Posted Apr 13, 2016 · 01:48 UTC#16
this worked, thank you very much!!!
Posted Jun 23, 2016 · 02:50 UTC#17
I have the 8100 and having the exact same problem as op. My igo directory is deleted. How exactly can I fix this problem. When I boot into test mode I am unable to paste files using USB to avic script. I receive an error "paste failed" or "unable to paste" ... Something along these lines.
Could someone please give me some insight in how to fix this issue.
Help is greatly appreciated.
Posted Jun 23, 2016 · 03:10 UTC#18
for the beginning it was necessary to use 1. AVICtoUSB script
Posted Jun 23, 2016 · 03:24 UTC#19
thanks   but however now my igo is gone and it says   please insert your sd card containing IGO content files,
my other problem is i cant seem to paste to the ext data folder
Posted Oct 18, 2016 · 20:34 UTC#20
I have same problem. How can be fixed!? I saw an link on another post to Mega, but the link is offline. If you ex-28 solved your problem, can you share the solution please?!
