X930bt Bluetooth staticy
By Inked75 · Apr 10, 2016in Problems/Troubleshooting💬 5 posts👁️ 1,703 views
Posted Apr 10, 2016 · 21:26 UTC#1
So I just updated the x930bt to the 2015 maps and the new bt firmware. When ever I play Pandora or any music over Bluetooth it's staticy. Also noticed the option for selecting wired or bt is grayed out in the menu. Anyone else have this issue?
Posted Apr 11, 2016 · 21:57 UTC#2
Some have said the most bluetooth issues are solved by removing the battery cable to make sure all power is removed from the unit to get a full reboot after updating.  Not sure if "static" is one of the issues, but it shouldn't hurt to give it a go.
Posted Apr 11, 2016 · 23:21 UTC#3
Yea  did that and it seems to have worked now i cant get the Pandora or the Bluetooth to connect to any of the music. The only thing i can do is make and receive phone calls
Posted May 04, 2016 · 16:09 UTC#4
Having the same issue after the update, Calls work but media does not
Posted May 04, 2016 · 16:30 UTC#5
Found a solution for this
Jefe2323, on 20 Jan 2016 - 8:36 PM, said:snapback.png
Sorry, I misspoke earlier. I AM running 3.32 and my phone will always connect to Bluetooth PHONE AUDIO but I have to manually connect to MEDIA AUDIO every time. For example, I have to go to BT source, hit 'connec't, then it gives me the 'follow the instructions on your phone' message. I then have to go to my phone settings and click 'media audio.'
Go to Settings/AV Settings and make sure "App Connection" is set to Bluetooth. BTW, I was having a similar problem yesterday - and my HU was doing weird things - like playing my wired ipod's music when I selected Pandora - instead of connection to the phone.  Somehow my HU setting for App Connection got set to Wired. After setting it back to Bluetooth, I also re-pair my Android phone to the HU. Now it is working as expected.
