Cannot Update to 1.11 from 1.05(NEX5000)
By Lewir · May 12, 2016in NEX Series💬 12 posts👁️ 2,343 views
Posted May 12, 2016 · 22:55 UTC#1
I installed a NEX5000 unit into my car last December and was able to successfully update from 1.01 to 1.05 however, i want to update from 1.05 to 1.11 and i always get stuck with "update error please make sure the update is the only file on your drive"
i have made sure the only file is AVIC5000NEX with its contents are on its drive on a flash drive, SD card, another flash drive and even reformatted all of them to FAT32, I'm at wits end can anyone help me here?
Posted May 12, 2016 · 23:26 UTC#2
If you downloaded it with a Mac, the mac puts hidden files.  If you have a windows box, use that
I'll assume you got that folder from the pioneer site.
Posted May 12, 2016 · 23:54 UTC#3
oh yes i also tried all of the above with my mac and pc because i do remember that macs do that and yes downloaded the file directly from the site
Posted May 13, 2016 · 01:51 UTC#4
Try a different brand USB stick.
Posted May 13, 2016 · 06:41 UTC#5
I've tried three now
Posted May 13, 2016 · 13:36 UTC#6
Are you putting the folder , or the contents of the folder on the USB stick?
Posted May 13, 2016 · 22:19 UTC#7
 Yep path looks like
 flash drive -> AVIC5000NEX - > contents
Posted May 13, 2016 · 23:51 UTC#8
 Yep path looks like
Ok, well it was a thought... being that you said it's telling you that the folder contains the wrong info, now it's hard to say.
Try re downloading it... you probably did already...
Could be a defective file.... call Pioneer to make sure of that...
Posted May 14, 2016 · 11:06 UTC#9
ill try giving them a call
i have re-downloaded it twice on two computers yes, maybe if someone has the file on here? or the 1.10 file?
Posted May 14, 2016 · 11:42 UTC#10
Are you plugging it into USB 1?
Posted May 14, 2016 · 19:57 UTC#11
yes sir, i had tried a different one and it say please plug back into usb 1 before giving me the error
Posted May 17, 2016 · 04:18 UTC#12
I happened to be poking around on another site looking for different things when I stumbled upon a thread that had something to do with firmware updates and the person had asked whether the parking brake was applied. That seemed to solve the problem for that person. Maybe it will help if you apply your parking brake.
