5200 NEX and you tube?
By Lara9261 · May 23, 2016in NEX Series💬 4 posts👁️ 1,569 views
Posted May 23, 2016 · 14:33 UTC#1
Hello
I just had a 5200 installed over the weekend and the only thing missing is how to see video from IPhone. Is there any cable or adapter that can sync with USB2 input?
Angel
Posted May 23, 2016 · 15:42 UTC#2
If you're using CarPlay, it doesn't do video (for obvious reasons). If you use AppRadio mode, it will show video provided that the parking brake is engaged (or bypassed). If you just want to display video from your iPhone from then all you need to do is use an AV adapter (same one for AppRadio Mode) with an HDMI cable into the HDMI input on the back of the head unit. USB will not pass video by istself. Need elaboration? Take a look at the owner's manual. It's all in there!
Posted May 23, 2016 · 16:46 UTC#3
Thanks rock
Thats the point the 5200 has no HDMI, AV adapter usb to lightning to video?
Posted May 25, 2016 · 04:36 UTC#4
Likely be cheaper to swap out the radio to get one with HDMI input, but you might find some setup that converts HDMI to Composite Video.
