power off
By ex-28 · Jun 02, 2016in NEX Series💬 19 posts👁️ 4,283 views
Posted Jun 02, 2016 · 13:31 UTC#1
is there a way to power the unit off  other then just screen off ?
can't seem to locate anything.
also i wish the center button on the remote could be used to skip preset radio stations , so much  comfy in the hand  rather then fighting to find the 2 smaller buttons at verry bottom of the remote.
Posted Jun 02, 2016 · 13:44 UTC#2
only the x200 units I belive, not sure if it's all of them.... any of the x100 and before can't do that
Posted Jun 03, 2016 · 21:33 UTC#3
On my 8100 I hit the middle button and select AV. On that screen is a power off icon. I stumbled on it one day
Posted Jun 08, 2016 · 22:15 UTC#4
.......and it turns the screen black. Thats it. The unit is still powered up.
Posted Jun 08, 2016 · 23:34 UTC#5
ok thanks , was hoping to get it to power down if needed , also  weather  on the map  is there anyway to get canada  to show up   as it only shows us cities and i have correct region selected.
Posted Jun 09, 2016 · 02:18 UTC#6
What are you looking for besides 'cities' ?
Posted Jun 09, 2016 · 23:50 UTC#7
just to have my local wether show up is all ,   im located in winnipeg manitoba canada
Posted Jun 10, 2016 · 02:26 UTC#8
Red in quote means U.S.  He's wanting his local Canadian cities.
Posted Jun 10, 2016 · 19:29 UTC#9
not sure what you're talking about. I get to a screen that among a bunch of selections has a power off selection. hit that and the unit turns off.
Posted Jun 10, 2016 · 23:17 UTC#10
Unless you have the 8200, no it doesn't. If you have a powered antenna, it'll stay up.
Posted Jun 11, 2016 · 00:50 UTC#11
Well ok mine turns off
Posted Jun 11, 2016 · 17:50 UTC#12
When you turn it back on without touching the car's key/ignition/pushbutton, does the unit reboot from the splash screen or does the screen just come back on? If it's the latter, then no your unit does not turn off. It's merely in "standby".
Posted Jun 12, 2016 · 19:55 UTC#13
Im curious why anyone needs the unit to shut off completely?
Posted Jun 13, 2016 · 03:51 UTC#14
because   the odd odd time if the map freezes  constantly trying to load ect ,  only way out  in my car is to put in park shut off my car and open driver door,  al that just to get the deck to reboot.
Posted Jun 13, 2016 · 06:01 UTC#15
Ditto... reboot the HU.  AFAIK, anyone with a computer understands the need or desire at times to do a reboot. :)))
Posted Jun 14, 2016 · 19:10 UTC#16
Do you have an 8200??
Posted Jun 14, 2016 · 19:46 UTC#17
If you read the entire thread he mentioned an 8100.
Posted Jun 15, 2016 · 22:57 UTC#18
Duh
Posted Jul 05, 2016 · 20:26 UTC#19
Is your screen removable? That should turn off the unit, it does on the 4100.
