So for those of you with iPhone, do you like Carplay better than Appradio?
I'm in the process of "learning" Carplay (I have the 4000NEX and was using Android with Appradio and the NetGear Push2TV thingy because the HDMI is very unreliable at least with my Samsung Galaxy S3/S4).
1) I see/know that Carplay has limited apps compared to AppRadio. Probably the only ones/things I miss are Waze since the 4000NEX doens't do google maps (at least with Android).
2) I like the Siri control, but I don't like that I can't use the Source button on my steering wheel to "stay" in carplay mode and switch the input. for example, in AppRadio with Android, I could use the Source button on the steering wheel to switch to XM/HD (while still "staying" in say, iHeartRadio). While commercials were playing/etc. Seems that in Carplay with iPhone 6s and the 4000 NEX I Have to push the NEX icon to get back to the main screen and then I can switch inputs. But that requires futzing with the head unit (ie: I cannot tell Siri to swtich inputs because that's outside her abilities). Note: I don't know if this is particular to Carplay in general or the particular head unit (ie: When/if Ford Sync3 gets Carplay, dunno if this is easier with the Sync system or not). I was kinda hoping for an all voice control.
3) Carplay for just needing/using the Lighting to USB Cable. Appradio still needs all the other connections/dongles (NetGear Push2TV isn't compatible with iPhone). although I don't know if iPhone is less tempermental with HDMI connection than my Galaxy phones are.
Thoughts/suggestions/ideas?
