Hello,
I just purchased an 8200NEX, and I am installing it myself. I got to the part where I am supposed to install the GPS antenna.
However, the antenna base is not magnetic. Is this a faulty part or is this common now with the newer units?
Thanks.
Hello,
Thanks.
Hello,
Thanks.
If Im correct there should be a double sided square piece/pad of tape. Mine was installed on the dash inside the car.
Yes, they included it. I ended up just attaching a small magnet to the antenna and installed everything on a metal bracket on the inside part of the dash.
