8200NEX With KICKER 11HS8
By Rocinante · Jul 12, 2016in NEX Series💬 2 posts👁️ 1,211 views
Posted Jul 12, 2016 · 02:31 UTC#1
I installed a compact Kicker 11HS8 150 watt subwoofer with my new 8200 unit.
The subwoofer is self-powered and connected to the h/u, and I also have a separate amp that is powering the four speakers.
However, the subwoofer is very under-powered, even after I set the filters correctly.
I have to lower the speakers to -24db and raise the subwoofer to 10db just to get it to marginal levels.
Is there anything else to try, or is this subwoofer just too under-powered?
Posted Jul 12, 2016 · 03:16 UTC#2
Make sure that you have the input level switch on the Kicker set to "Lo". Also make sure the gain control on the Kicker isn't all the way down.
