Waze v4.9 Appradio mode support
By wei803 · Jul 21, 2016in AppRadio, AppRadio 2, AppRadio 3💬 5 posts👁️ 2,296 views
Posted Jul 21, 2016 · 04:19 UTC#1
It appears that Waze are listed as supported with v4.9 update on Pioneer website: https://www.pioneerelectronics.com/PUSA/Car/AppRadio
Can someone confirm it? I've been holding update to v4 cause the support was broken.
Edited Jul 21, 2016 by wei803
Posted Jul 23, 2016 · 03:10 UTC#2
I never had issues with waze on my Android -- is this an issue specifically with Apple iOS or both?  (Personally, I used it just to see how it works and my Android updates Apps automatically and don't use it often.  I have yet to try it on my iPhone.)  Are you able to downgrade if the update doesn't work?   If so, I would steer to update, then downgrade if does not work or it lost key features.  Anyway, thanks.
Edited Jul 24, 2016 by bitmap
Posted Jul 23, 2016 · 18:19 UTC#3
Yes, I tried Waze version 4.9 and it does work.  The setup I used was an iPhone 4S, AVIC-Z150BH w/ AppRadio connected to Waze version 4.9.  By the way, it appears android only has version 4.6.
Posted Jul 25, 2016 · 04:37 UTC#4
Thanks for the reply. Yes sorry forgot to mentioned it's iOS.
But the problem where the menu block most of the route map view still there, hope they will look into that.
Sticking to v3.9.4 at the moment.
Posted Jul 30, 2016 · 17:27 UTC#5
Please post a picture, or URL to a picture, so I can see more specifically what you're referring to.
I came across the following AppRadio World link and it looks like others (2/4) are using 4.9 with no issues depending on the systems (and/or) knowledge(?):
http://www.appradioworld.com/2016/01/waze-drops-pioneer-appradio-mode-support.html?showComment=1468582572668#c7040061948568624877
Update 0:
I am in the process of updating to Waze 4.10.0 and iOS 9.3.4.
Update 1:
I didn't test this in depth but I set a location from wi-fi and went into my car and started AppMode and it appears to work fine for the little I tested it.
Update 2:
I am in the process of updating to Waze 4.11.0 and iOS 9.3.5.
Edited Aug 28, 2016 by bitmap
