Auto EQ: Set EQ to Flat?
By Rocinante · Sep 05, 2016in NEX Series💬 4 posts👁️ 1,466 views
Posted Sep 05, 2016 · 22:41 UTC#1
Does it matter?
I would like to fine tune the EQ after the procedure.
Posted Sep 05, 2016 · 23:41 UTC#2
AutoEQ tunes your flat setting to "flat hearing".
Before AutoEQ:  Flat PRE > Flat EQ > Amp > Speakers = Not-Flat Sound
After Auto EQ:  Flat PRE > Flat EQ (AutoEQ ON) > Amp > Speakers = Flat Sound
...................or:  Flat PRE > Adjusted EQ (AutoEQ ON) > Amp > Speakers = Not-Flat Sound, but EQ'd to your taste.
At least that's how it works in theory.
Posted Sep 06, 2016 · 00:47 UTC#3
So, Auto EQ creates its own settings that are not based on what the EQ was manually set to before the procedure?
Or, do I need to set the EQ to my taste before the Auto EQ is performed?
Edited Sep 06, 2016 by Rocinante
Posted Sep 06, 2016 · 05:06 UTC#4
User EQ is set to flat automatically during the AutoEQ calibration process.  You have to EQ to your taste afterwards if you do not like AutoEQ flat (when ON).
