new 8200nex turn by turn navigation no sound
By Tvaclavek · Sep 25, 2016in NEX Series💬 5 posts👁️ 2,493 views
Posted Sep 25, 2016 · 16:35 UTC#1
Just had the 8200nex installed in my 2016 jeep wrangler.  Had it done at best buy with maestro and everything is working except that I have no sound when Im using the navigation.  Doesn't matter what app I use or if I use the head unit's navigation.  Wondering if this is a hardware issue or if the installer maybe didn't hook it up right. Or maybe it is something silly that I don't know to look at it.  Has anyone had this issue?  Ive tried everything.  Searched this site and google and can't find anything.  Any help would be appreciated.  Thanks!
Posted Sep 25, 2016 · 22:10 UTC#2
if it does not work BT audio and Navi something you do not usually installed device.
Navi audio is output from the front speakers.
Posted Sep 26, 2016 · 17:19 UTC#3
I tried plugging my usb into the center console and now ulink works but only if I don't have the phone connected via bluetooth.  Turn by turn audio still not working.  Guess Ill make an appointment and have them look at it again.
Posted Oct 08, 2016 · 01:27 UTC#4
I have no navigation sound on my 8100nex as well from Google Maps or the built in navigation. I still haven't figured it out. Everything else works and the alert volume is cranked up. My microphone doesn't work for voice commands either... But it works fine calling people and talking to them. Something has to be up with the hardware. I reset the deck and upgraded to 1.05 and still no luck. Not sure what causes this... But it is super annoying. I know it is installed correctly because I did it myself... And it worked fine when I put it in... Then it just quit working like 2 days after. I've looked everywhere too, and have found no solution.
Posted Dec 29, 2018 · 18:35 UTC#5
Storm8383, I am having the same issue that you described.  Did you find a fix for this?
