z110bt Tuner Error...
By nezfotnemom · Oct 04, 2016in Hacks/Mods💬 4 posts👁️ 1,603 views
Posted Oct 04, 2016 · 19:36 UTC#1
Having an issue with my buddies z110. He did the 2015 maps update from the other thread and ever since, getting this error.. he doesnt even have a tuner installed.. Do you know how to force the upgrade with test mode? Getting this error
http://imgur.com/a/s1uKr
Posted Oct 04, 2016 · 20:17 UTC#2
Presumably he wasn't getting this error before the upgrade.  And that nothing odd happened while installing 2015.  By "he doesn't even have a tuner installed" I assume you mean a traffic tuner.
Was he upgrading (to 2015) from the original Z110-BT firmware? Or did he have a newer version? It matters because the original Z110 used an optional MSN traffic tuner (ND-MDT10). Support for that went away in the Z130 firmware (ver 3 firmware). That's when the newer RDS based ND-TMC10 tuner support appeared. But if the old MSN tuner was present - you got a similar message.
Are you absolutely sure he didn't have the ND-MDT10 installed?
If it is installed, he needs to unplug it. If there isn't one - I'd force a cold reset (disconnect the battery for a few minutes) before doing anything else.
Regarding falling-back to old software, there are a couple possible solutions.
Testmode does have a couple "force write" from SD functions. But I've never used them and they seem very dangerous. You'd need the old version on SD in the proper format (which I don't know what that is).
An easier and less risky method would be to use the previous version that is installed on the unit. There are two copies of firmware installed on the unit. They are in USER/PRG0 and USER/PRG1. The one that gets loaded during a cold boot is controlled by the presence or absence of the file /USER/PRG.FLG. If this file is missing, create on (just a empty file). If it exists,, copy it to your testmode SD (for safety) then delete it.  DON"T touch anything else. If this doesn't work, it is easily reversible.
Edited Oct 04, 2016 by RonS
Posted Oct 04, 2016 · 20:27 UTC#3
Presumably he wasn't getting this error before the upgrade.  By "he doesn't even have a tuner installed" I assume you mean a traffic tuner.
Was he upgrading (to 2015) from the original Z110-BT firmware? Or did he have a newer version? It matters because the original Z110 used an optional MSN traffic tuner (ND-MDT10). Support for that went away in the Z130 firmware (ver 3 firmware). That's when the newer RDS based ND-TMC10 tuner support appeared. But if the old MSN tuner was present - you got a similar message. Are you absolutely sure he didn't have the ND-MDT10 installed?
Yes he does not have the ND-TMC10. I will check out the PRG.FLG option and report back. .
Posted Nov 15, 2017 · 23:31 UTC#4
Sorry nezfotnemom, old thread - but we've got another Z110 throwing this error after the 2017 update. Also doesn't have the traffic tuner. How was your buddies problem resolved?
