7200NEX, iGO Not Working, Help, SD Card
By mcnegron90 · Oct 05, 2016in NEX Series💬 5 posts👁️ 10,910 views
Posted Oct 05, 2016 · 21:02 UTC#1
Hi,
I have the 7200NEX and when you select MAPS it says iGO loading and then it closes. Everything else with the unit is working well.
How can I fix this issue?
Where is the SD card located?
Are there any step by step instructions?
Thank you for the help! :)
- Matthew
Posted Oct 06, 2016 · 01:28 UTC#2
Seems like we've had a lot of these...this is what I had to do. Might be the same thing as yours:
http://tinyurl.com/z3y7uze
Posted Oct 06, 2016 · 10:16 UTC#3
[symptom]
When pressing the "NAVI" icon on the navigation model, the Map is not displayed.
"Loading iGO..." appears and then return to the previous screen.
 [Cause]
The license file on the SD card is damaged
[Remedy] Only applicable for the above symptom!
update/rewrite the SOC ucom with latest firmware
No need to replace the SD card.
Installing the latest firmware which is published on the consumer website.
Posted Jan 14, 2017 · 18:30 UTC#4
[symptom]
 [Cause]
soc ucom?
Posted Jan 14, 2017 · 18:32 UTC#5
same problem as listed.  I have read the forums about unlocking sd card.  Add new map/licensing.  Thats the fix?
