AVIC-8000NEX....Radio not working
By primetime · Oct 24, 2016in NEX Series💬 4 posts👁️ 2,716 views
Posted Oct 24, 2016 · 03:43 UTC#1
2009 Honda Accord EXL no Nav, but with 7 speaker premium system.
Everything is stock, except the pioneer avic-8000NEX.
I'm not getting any AM or FM radio.
I'm using Scosche HAAB antenna adapter and Metra 70-1730 wiring harness. I have the blue/white wire from the Metra 70-1730 wiring harness connected to the Blue/White wire coming from the NEX 8000 harness and I also spliced the blue wire from the HAAB antenna adapter into this connection.
NEX 8000 Blue/white wire
Metra 70-1730 blue wire
Scosche HAAB blue wire
These 3 are all connected to each other.
The HAAB is snapped into the proper connector "D" from the factory wiring harness, and the silver antenna adapter is plugged into the back of the NEX 8000.
Why am I not getting any radio signal?  Perhaps the HAAB is bad? I have a Metra 40-HD10 on order.  I even tried hooking up the blue wire on the HAAB to the red switched 12v source wire as well and it still didn't work.  I am able to see on the display for HD radio the artist and the song on FM 92.5 for example, but no audio.  Everyting else like music played off a USB stick works fine.  Is there a wire on another factory harness that I need to tap into for the powered antenna source?  I thought that is the point of the Metra 40-HD10/scosche HAAB antenna adapter.   Only Honda factory harness plugs A, D, and F below are used with the AVIC 8000NEX.  "D" is for the factory sub, "F" is for the antenna, and "A" is the main radio harness that is pluged into the Metra 70-1730.
I installed the factory radio just to check and the AM/FM radio plays just fine.  There are no "bent pins" or wires not properly seated in their connectors. Cavity A16 pink wire from factory harness "A" is confimed to hook into the blue wire location on the Metra 70-1730.  I even tried a Scoche HA11B wiring harness for the hell of it and I get the same exact result, (except no factory sub signal)
What am I missing?
Factory wiring diagram for 2009 Honda Accord Premium Audio System without Navigation:
Edited Oct 24, 2016 by primetime
Posted Oct 24, 2016 · 07:18 UTC#2
I think you have a hardware problem (
Posted Oct 24, 2016 · 12:31 UTC#3
Are you thinking the 8000NEX itself is bad?
Posted Oct 24, 2016 · 14:40 UTC#4
My 8100NEX worked fine for 8 months then just quick. My guess is a hardware problem for yours also.
