I too have been getting various lockups/freezes. Sometimes it doesn't seem like temp has anything to do with it. Has anyone had a freeze since successfully installing the update? I'm going to be installing it later today.
Does the Firmware update work?
It appears to be working. Yesterday it was 90 degrees outside. I wasnt using a heatshade at all, and there wasnt a cloud in the sky, it had to be high 90's in my car. My car sat all day in the parking lot (from 8am till about 3pm). Now, normally I would start my car and expect the z2 to just sit there at the loading screen, but still be able to hear my radio station.
However, that did not happen. Instead, the unit started up just fine, loaded and all that like it was supposed to and I went about my way. Nav came up fine, not choppiness, nothing. I didnt try to play any of the music I have on my HD, but I expect it would have worked fine as well.
So... it looks like the patch is working like it should. We'll give it some time and see if it is consistant.
Thanks!! I'm going out to install it now. It will be nice to have the damn thing work more than once in a while.
I've installed it also. So far so good
so far update seems to work outside temp today was 91 look like it might have fixed the problem so far --but want to see what it will do when it hits 100 +
Today it was 87, but my truck sat in the sun all day and when I got in the temp read 103. Started her up and it worked!! Time will tell, but I think they may have actually fixed the problem.
Hasnt frozen since the update.. Doing well here.
Its been working fine for me since the update.
No hot days since then but no skipping either. Usually I woule either get one of the two, and probably one day out the week the system would work like it suppose to (well on start up that is). I'm happy so far, do not understand it but happy.
ITS WORKS!!! its about time.. i drove around all day with the heater on and it starts up evertime .
I did the patch as well on my Z1. Worked very easily.
I also noticed that my unit boots up faster.
after 4 weeks no freezes and today it was 65f outside and my unit froze, tried putting the HD in front of the ac for 3-5 min and that didnt work [my old standby that worked flawless on 100f plus days]
burned the update to a cdrw installed the update cd to the z2 froze screen and all and in less then 5 minutes it was fixed and working properly.
i looked at the files inside the update and it looks like they rewrote the operating system. this was not just a data from cpu to hd issue or it would have just been a few drivers.
i still know heat had/has issues with the Z2 as this all started on hot days for the majority of the posters here.
It's been almost a week and not a single lockup/freeze. I've gone about 1000 miles since the patch install with a lot of starts and stops. I think this might have really fixed it (Fingers crossed).
if this is what most are seeing....then regardless of if mine was freezing or not....it's worth a shot for me....mine seems to boot a little slower lately....but I've also added more music in the past weeks....
but then again.....pretty much any speed of bootup is better than a freeze....
it was 75f and had a song skip/play 95% and then go to another track.
still think these HD,s are jacked
Yeah, mine doesnt freeze but did the update anyways. It does definitely boot up faster.
does the new update for the freezing affect video lockout on the z1 if you have yours bypassed?
Bypass is not effected.
I tried just dumping the folder and the file to the CD-R using the Windows default copy feature in Vista but did not work. Should I use Nero or something? Any info would be greatly appreciated. Thanks.
Posted: Thu Sep 27, 2007 8:09 pm Post subject: What did you guys used to burn the fiels to the CD-R?
I had the same problem with a Vista burned data disc. I had to use Roxio to burn a mode 1 single session disc. Worked fine after that, though I did have the update failed loop for a while. Booted fine after that.
