Memory problem
By ryda4l5 · Sep 19, 2007in Problems/Troubleshooting💬 3 posts👁️ 614 views
Posted Sep 19, 2007 · 01:05 UTC#1
hi all i'm having problems maintaining customized settings on my D3. it will not memorize my preset radio stations or illumination colors. if i turn off the car and turn it back on in 10 sec everyting works like a charm but if it is shut of for more than 10 sec all my presets are back to factory!?
Posted Sep 19, 2007 · 01:09 UTC#2
Check to make sure you power wires are hooked up correctly.
The +Battery wire should be connected to a constant power source, not a switched one.
I also recall someone else having the same problem in his car.
Try searching some of the other topics for it.
Posted Sep 19, 2007 · 01:19 UTC#3
i did connect the +Battery wire to the fuse box but the wire that i used to extend the yellow wire is a bit bigger gauge than i wanted to use. i may try n replace with a smaller gauge anyone else experence this or fixed it?
