My USB lighting cable died today on the radio so popped the radio out and replaced the broken USB for a new one and all way good. I pushed the radio back in then then it wouldn't power at all. I checked and doubled checked and all wires were good. I removed the radio with the loom and popped it on a separate power supply and again no power.
changed the fuse etc and nothing.
by chance i touched live constant and live ignition together and the radio powered like normal ? however in the car the wires hadn't touched as they all had the correct seals in place on the bullets.
what i have to now do is like i had it on the bench both powers on the pioneer loom together to constant live to keep the radio settings, a push switch on the dash from ignition live to pioneer loom. This makes everything work how it did before the USB cable just stopped working.
What could have happened ???? its almost like the radio requires 24v to power now ????
