AVIC X930BT background lights (around the knob) out
By wascapsfan · Dec 23, 2016in Problems/Troubleshooting💬 7 posts👁️ 1,522 views
Posted Dec 23, 2016 · 02:00 UTC#1
Hello,
I just removed my AVH3200 BT & U220, and installed a X930BT and used the same wiring harness.
The AVH3200 BT worked flawlessly.  The AVIC X930 BT works nearly perfectly.  The only issue that it has is that the lights behind the buttons are out.  EVERYTHING else works perfectly.  The LCD Screen, navi, and everything are functioning well, but just the background lights are out around the knob. I hooked the unit up on my bench and the lights came on, but not after i installed it.
I figured that the hookups were the same since the plug was the same.
I'm wondering if the AVH3200BT does not need the orange wire hooked up and the X930BT does... I wired the AVH3200 4 years ago, so I don't remember if I hooked it up or not.
Dave
Posted Dec 26, 2016 · 03:05 UTC#2
Seriously???  I ask for help and you send a bunch of garbage???   Stay off the forum if you only want to send spam.
I nuked the spammer. :)  RonS.
Edited Dec 26, 2016 by RonS — Reason: feedback about spammer
Posted Dec 26, 2016 · 14:45 UTC#3
Hello,
Dave
My only suggestion is to check your harness wiring to the car's lights. If you don't have a x930 installation manual, you can probably download it from the Pioneer site. I'm guessing either the harness pin-out is different or the illumination wire (orange/white) isn't connected.
BTW, I wouldn't assume that your old power connector is the same pin-out as the X930. There are often differences even with similar units. If you have the correct x930 cable (should of come with the unit), check pin location for the orange/white wire. If you don't have the correct x930 cable - you can buy one from Pioneer, Amazon,  or ebay (google CDP1307).
You can do a Backlight and Illumination Test in Testmode (7. Monitor Testmode).
Posted Dec 26, 2016 · 18:51 UTC#4
Thank you Ron.
I'm going to redo everything on Tuesday.
I'll report back
Posted Dec 27, 2016 · 21:46 UTC#5
I
Edited Dec 27, 2016 by wascapsfan
Posted Dec 27, 2016 · 22:27 UTC#6
In test mode.  I tried everything in #7.  No luck.  Everything turned white, and then blue, so I was almost home free.
I put all the plugs back in and everything worked.  I then installed it and the lights went out again.
I actually went through all 60 something, but didn't touch what I wasn't familiar with.
No matter what I do, I cannot get the led lights to stay on.  It wouldn't be such a big deal, but the buttons around the knob are impossible to see at night.
I also like having a unit that works completely.  The update took without any issue.
Posted Dec 30, 2016 · 20:02 UTC#7
UPDATE (SOLVED)
Opened the unit up to find that the ribbon cable was not locked in and adjusted properly.  I removed the cable from the lock, then reinstalled it and it worked..
AWESOME!!!!!!
