I want to be able to PAUSE or TURN OFF playback of media (CD, DVD, SD-Card- or just turn OFF the radio!) immediately with the press of a (1) button (an actual, physical hardware button, either below the screen or a steering wheel control button)...
There does not seem to be any built-in way to do this that I am aware of (with a single (or simultaneous) button press).
This is the single most frustrating "lack of feature/control" of the AVIC Z-series- for ME. EVERY head unit I've ever had (whether stock, or aftermarket) has had a physical/hardware POWER button (or knob- turn volume to 0, then 'click' OFF), and nearly all have had a physical PAUSE button applicable to playing media (CD, tape, etc.)
I can't fathom how Pioneer's design team decided it was OK for their "flagship" device to be missing BOTH of those buttons!?!
Ideally I would like the button on my steering wheel that is set-up to MUTE the audio/sound (although it actually just attenuates the sound instead of fully muting it- regardless of settings! Also VERY frustrating!), to PAUSE playback instead of MUTING (when the source is "pausable").
Does anyone have any thoughts, insight, ideas, hacks, work-arounds, alternate solutions, comments, etc?
I am aware that it is possible to pause playback by pressing an on-screen "button" when the display is in the proper mode... However, I almost always keep the display on the Navigation screen... and when I need to PAUSE the playback it tends to be a 'semi' emergency; and it needs to be as immediate/instantaneous as possible. Pressing the button to switch to the media control screen, waiting the 1-3 seconds for that to come up, then find & accurately press the pause button is not acceptable.
The main reason that the MUTE function is inadequate is because I need to resume playback from whenever I muted it- and finding that point is quite tedious and frustrating.
I just want to be able to press a button and make the sound STOP/PAUSE (and later resume from that point if the source was local media)!
Is that really too much to ask from a device with such a price tag?! Apparently: YES, that's too much!
I'm wondering if there may be some way to reprogram the control buttons on the steering wheel (SWI-RC)? Or perhaps use "test mode" to reprogram one of the physical buttons- or to 'add' an additional, alternate "control" accessible by "long press" or even pressing two buttons at once...? I really am just guessing/hoping!
This system was in the car when I bought it so I've been trying to figure out & learn about it as needed...
ANY and ALL responses (whether comments, assistance, guidance, telling me I'm an idiot, whatever...) will be greatly appreciated!!!
THANK you so much!
