Need clarification b4 commiting z2
By CrazyCowPie · Sep 19, 2007in Hacks/Mods💬 8 posts👁️ 1,259 views
Posted Sep 19, 2007 · 23:34 UTC#1
From what I've read, if I install Avic-Z2 and download the 30MB file in the sticky post for Z2 bypass; all I need to do is insert this CD and upgrade the Z2, then do the 2 wires grounding and I'm good to go with the video bypass?
Thanks for any input!
Posted Sep 20, 2007 · 00:18 UTC#2
Yes. If you happen to buy one that was manufactured after sometime in July, it will already have that file in it to allow it to be bypassed so you won't need to bother
Posted Sep 20, 2007 · 02:06 UTC#3
Alrighty then...thanks!
Take now, bye bye then
Posted Sep 20, 2007 · 06:42 UTC#4
Just to confirm, if the unit was manufactured before July (mine was May 2007), then I will need the 30Mb .iso file. Correct?
Posted Sep 20, 2007 · 07:28 UTC#5
Yep. Unless someone did it already
Posted Sep 20, 2007 · 13:08 UTC#6
Nope... Just recieved the unit this week and will be installing tomorrow.
Thanks for the info!
Posted Sep 21, 2007 · 02:01 UTC#7
If the Z2 unit does not needed, but one use the 30mb file update anyways, would that hurt the Z2?
TIA!
Posted Sep 21, 2007 · 03:40 UTC#8
No. It will just give you a prompt that its already done
TIA!
